XS Power
xs power D3400 top post wont fit knukonceptz batt terminals
i have a D3400 under my hood and i have a i bar 555 kit for it and i tried to put this knukonceptz battery terminal on the top post that came with the i bar 555
http://www.knukonceptz.com/productDetail.cfm?prodID=KBT-30P
when i tightened it all the way it still came right off
what top post adapter do i need to get so this battery terminal will fit the battery?
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Are you sure you don't have the pos and neg posts of your ibar backwards? They are different sizes.
HU: Pioneer
Highs: 2X 4X6"s, 2X 3.5"s, 4X 5.25" comps, Q-Logic kicks, and a Sundown SAX-125.2
Subs: 4 Nightshade 15s and Strapped SAZ-3500Ds <---Sundown FTW good.gif
Electrical: dual DC Power 320s (ordered) and 2 D3400s up frt and 4 D2700s in the back
.ʇı ɥʇıʍ ʞɔnɟ ʇ,uɐɔ noʎ 'ʞɔıp ǝɹos ɐ ǝʞı1 sı uʍopunS
iv always had bad luck with those kinda battery terminals, on my yellow top specially. i usually use the regular batt terminals and use a bolt/screw to connect them to the battery.
im thinking putting something around the battery post to make up for some space that way it lets the terminal tighten up. just an idea
Edited by BeatBox
yeaa i switched em and made sure
its actually for a buudy of mine thats going to buy a xsD3400 for under his hood but i already have mine so we tried it on mine
ill just have to figure something out
my stinger ones have an insert for inside them to make them fit....
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
The issue is the Knu terminals. The compression fitting is awesome, however the screw to secure it onto the post is lacking. It feels like it tightens down, and there is no wiggle...but if there is any tension on the wires at all, the terminal twists and slips right off; even fully tightened. You have to find the perfect angle for the terminal and wires to get it right.
These things are expensive, so you could try scoring the inside of the terminal to give it more bite on the post...but I said screw it and went to flat terminals and washers to make sure there are no issues.
However, I have to say I am not impressed with the quality of the ibar kits...as the metal screw/bolt points break out of the surrounding plastic with very little effort (very similar to the Knu terminals, but rather than slipping off, they break)...and others I know have had the same issue. Not up to the quality of the batteries, which are really amazing. 30+ bucks gone in a flash, so be very careful about putting even a little bit of stress on them!
my s3400 wont fit ANY of the knu terminals, ive tried them all, and my yellow top the posts were too big so they wouldnt go on all the way..
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
  • Who's Online   0 Members, 0 Anonymous, 1941 Guests (See full list)
