BigRed Posted July 9, 2010 Author Report Posted July 9, 2010 Don't mix subs, please ! Maybe you'll make big numbers, but will it sound good ? I don't think so ! Good luck with this (big) build. They are all the same brand no worries mostliky model aswell. But what is wrong with mixing subs? If they are differnt box and tuned and used for only certain Freqs Red
VIP3R Posted July 9, 2010 Report Posted July 9, 2010 They are all the same brand no worries mostliky model aswell. But what is wrong with mixing subs? If they are differnt box and tuned and used for only certain Freqs why do you see a need to do so? subwoofers can handle the frequencies...thats what they are meant to do...you dont need a 15 playing 25-35, a 12 playing 35-45, etc....pointless..thats what your making it sound like. nor does that situation really work...you would need a big crossover setup. ha. just get the same size configuration. make sure you have the airspace. less subs with proper airspace > more subs without proper airspace. simple. you can use a 8 or 10 for midbass...ive seen that...but you make it seem like what i described above. 2 Sundown Audio SA-10s Box built by Speed of Sound Kicker 1500.1 Infinity Ref 475a Rockford Fosgate T1682c 6x8s Pioneer Premier DEH-510UB XS Power D6500 Stock 130amp Alt Big 3 Build Log
Ray Posted July 9, 2010 Report Posted July 9, 2010 one thing you might want to consider is total displacement... which is SD * Xmax... that gives you total air volume being moved... Thank GAWD, someone on this forum with a brain. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
fritosaregood Posted July 9, 2010 Report Posted July 9, 2010 You cant really compare alot of lower power subs to few higher power subs, but off of cone area. more things come in to it like motor size/strength, excursion, and probably some others i can think of right now. whenever i compare setups between going with a lot of lower power subs vs a few higher power subs i look at cone area and excursion. to get the total displacement comparison first. not just cone area. also you dont wanna use 10 subs with 50 oz motors vs 4 subs with a 500 oz motor each...usually seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
BigRed Posted July 9, 2010 Author Report Posted July 9, 2010 Ya i See alot about what you guys are talking about for sizes now. Its not nessesarly bad just unnessesary. Ill try and redraw. I was going for the most subs with still proper box space thats why i mixed sizes. Now i keep hearing you say air space. Air you talking about inside the box or outside? Cause i have no idea what you have to look at with air outside of the sub Red
BigRed Posted July 9, 2010 Author Report Posted July 9, 2010 Good Luck with this looks like alot of work. I've done alot of fiberglass before. The only thing i'm looking at right now is kinda what to fiberglass ha. you know? I don't wanna put in time and effort to find out i could have something better with less work you know? I just need to find a boss configuration thats gonna get me some rep Red
BigRed Posted July 9, 2010 Author Report Posted July 9, 2010 okay now im thinking screw it and just putting in 2 18" fi btls Except i dont know much about these. How many max watts can they handle? Red
VIP3R Posted July 10, 2010 Report Posted July 10, 2010 Ya i See alot about what you guys are talking about for sizes now. Its not nessesarly bad just unnessesary. Ill try and redraw. I was going for the most subs with still proper box space thats why i mixed sizes. Now i keep hearing you say air space. Air you talking about inside the box or outside? Cause i have no idea what you have to look at with air outside of the sub airspace inside the box. for example.. a 18 fi btl needs 5-10 cubes ported okay now im thinking screw it and just putting in 2 18" fi btls Except i dont know much about these. How many max watts can they handle? 2000w RMS rated. can do more power if you know what your doing and have the electrical. 2 Sundown Audio SA-10s Box built by Speed of Sound Kicker 1500.1 Infinity Ref 475a Rockford Fosgate T1682c 6x8s Pioneer Premier DEH-510UB XS Power D6500 Stock 130amp Alt Big 3 Build Log
audioanonymous Posted July 10, 2010 Report Posted July 10, 2010 More is NOT always better. There's too many variables to the whole equation. Cactus Sounds USA Team Captain Multiple World Record Holders
