My ap 1500 gets so hot after 10 min and goes into portect when I turn the volume up, what could this be from? I have a incriminatir dr 18 hooked up to it and it's starts to smell bad I have all 0 gauge and a extra battery hooked up
Where's your gain set? And as above, what ohm load is it wired to.
Those things generally either work properly or die completely...
10.x volts fo' life!
sounds like your clipping the shit out of it
edit: my ap1500 gets warm but never gets real hot and has never shut off. my amp is mounted on the seat and it is closed all the time with only a couple of inches of room for it to breath.
Edited by loudREcivic
2015 silverado crew cab
nothing atm but soon...
My volt never go under 12 and it's wired to 1 ohm
It's a dual voicecoil 2 ohm right?
How did u set the gains?How is the bassboost set up?
How much do you turn up the HU.
Yes and my gain is at half and the bass boost is off
Oke, at half, but how did you set it up?
By ear?
Using a DMM?
Using a Oscope?
Or did you just turned it up?
By ear
At the very least get a DMM. You literally can't hear well enough to prevent all distortion.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
