quick meca fuse question
As the title states, I want to know if you can change - say a 40 amp factory fuse to a 30 amp. After I did this swap twice, it'd make me a little bigger fish in a smaller pond. It's a temporary set up, but I want to to go get my feet wet. Thanks for the info, W
Stetsom 11K2d
6-12" DC XL's
8 batts
Ohio Generator alt
2 punch 400's, 8 goldwood 6.5's, 4 selenium st200's
2010 MECA AS1 champ 146.7
Team DC I'm on the wagon, driving a wagon!
'90 Camry Wagon
155+ on music
member of MECA, FCBC, and IASCA
{(Total Amperage of In-line Fusing X 10) + Woofer Cone Surface Area} = Pressure Class #
Please consult Division Rules for complete definitions.
Examples:
30 amps + 2-12 = 526 40 amps + 1-12 = 513 30 amps + 1-15 = 477 50 amps + 1-18 = 754
50 amps + 1-12^2 = 644 50 amps + 2-12 = 726 100 amps + 1-15 = 1177 100 amps + 2-18 = 1509
50 amps + 2-10^2 = 700 100 amps + 2-12 = 1226 200 amps + 2-15 = 2353 200 amps + 2-18 = 2509
50 amps + 3-10 = 736 200 amps + 2-12 = 2226 400 amps + 4-15 = 4707 400 amps + 4-18 = 5018
Fuse Requirements for Qualified Score: Fuses must have value stamped in the metal, except ATC
Permitted: AGU, AUE, ANE, ATC, ANL, or Mini-ANL (also known as MIDI); 32 volts maximum
SP - Sound Pressure Format
Measures dB inside the vehicle. 15 “Pressure Classes” in 4 Divisions
AS - Amateur Street - Basic, daily use systems. Beginners & those who have not been champions. Owns equipment. No Pro’s.
AS1 0 - 550 -- 1 Fuse Maximum
AS2 551 - 1000 -- 2 Fuses Maximum
AS3 1001 - 2000 -- 3 Fuses Maximum
S - Street - Intended for daily driven vehicles. Competitors show who can do the most with the least.
S4 2001 - 4000 -- 4 Fuses Maximum
S5 4001+ -- Fuses Not Required
M - Modified - Intended for vehicles and systems that are designed to maximize Sound Pressure level, including woofer walls and
pick-up truck cut-throughs, but are still capable of being daily drivers.
M1 0 -550 -- 1 Fuse Maximum
M2 551 - 1000 -- 2 Fuses Maximum
M3 1001 - 2000 -- 3 Fuses Maximum
M4 2001 - 4000 -- 4 Fuses Maximum
M5 4001+ -- Fuses Not Required
X - Radical X - Vehicles with major modifications; for the hard-core Sound Presssure League Competitor.
X1 0 - 4000 -- Fuses Required
X2 4001+ -- Fuses Not Required
DB - Drive-by SPL Parade Format
Measures dB outside the vehicle, in 5 “Pressure Classes”, while playing full-range music.
DB1 0 - 550 -- 1 Fuse Maximum
DB2 551 - 1000 -- 2 Fuses Maximum
DB3 1001 - 2000 -- 3 Fuses Maximum
DB4 2001 - 4000 -- 4 Fuses Maximum
DB5 4001+ -- Fuses Not Required
hope this helps a little
NoFearX18 said:
trainman0978 said:
Thanks for the info Chode, but I've been crunching numbers already. The thing I really need to know is, will the judges frown on me using a smaller than reccomended fuse size? I am wanting to change from my gear's reccomended 80 amps down to 60 amps. I'd be in the low 900's with my 4-10's. The stock pair of 40 amp fuses puts me into the much bigger 1001-2000 class, which would probably put me way out of my element. New build coming soon.
Stetsom 11K2d
6-12" DC XL's
8 batts
Ohio Generator alt
'90 Camry Wagon
155+ on music
lol the judges dont care they go by the numbers i was useing a 12k with 2 8 0 amp fuses to set records and was no problem with it all
I thought that was the case. Thanks for helping the newb. :good:
Stetsom 11K2d
6-12" DC XL's
8 batts
Ohio Generator alt
'90 Camry Wagon
155+ on music
  • 2 months later...
Will they frown on you for running small fuses? No. How do you think some of us are getting big #'s in a low class? :)
yea like ben with his magic 5 amp fuses with magic spl dust lol
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
Dude i have seen that s10 round town.. Where bouts you stay at?
AS Far as switching fuses it shouldnt be a problem. A guy at the last show switched out 2 40 amps fuses for 2 10s to get into a lower class
Long way past this point, now. It was useful knowledge for me in the past; as it will be useful for someone else in the future, I'd say. Imagine how I felt reading the Meca rules, with my system either bought or sort of in my mind, and thinking I'd be in some mega-class with my little set up!
Stetsom 11K2d
6-12" DC XL's
8 batts
Ohio Generator alt
'90 Camry Wagon
155+ on music
i hate to tell u this mecca guys but this is the thing that will stall the sport
Team SSBTeam SoundStreamTeam Tsunamiteam ohio generator
  • Who's Online   1 Member, 0 Anonymous, 1941 Guests (See full list)
