depends on what your running. but the answer is probably yes. unless all your doing is music and internet. then it might not.
2 12" memphis mojo mojo12d4
hifonics brutus bxi 2610D
1/0 power wire
4 gauge speaker wire
ddm tuning 8000k 35w hids
C&D technologies battery (100 ah)
custom box tuned to around 45hz(designed buy fritosaregood)
2010 kia forte koup
I wouldn't bother with it, unless you really plan to oc, those 5300s will oc like a bitch
My current 95 Jetta Build w/
pioneer h/u
2 RD Sonance 10's with flatwind coils
2 Audiopipe apsm 1500.1s
1 Hifonics Brutus Elite 60x4
1 XS d925
1 Stinger spv35
1 1000 amp lead acid
50 ft of 0/1 ofc from Audiotechnix
all powerbass components, and coaxils, 4 sets
buildlog = http://www.stevemead...2-rd-10s-build/
My build for my wife. http://www.stevemead...01-f-150-build/
5-20? it takes like 1-2.
1/0 power wire
2010 kia forte koup
counting power down and power up lol B)
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
well i assumed it would be shut down to start with. install time i never include shutdown and start up. cause as long the motherboard supports the cpu theres nothin else to install which meas you don't have to start it back up right then.
1/0 power wire
2010 kia forte koup
Well... I would think with the 600mhz difference, that you should be able to OC the 5300 at least that much more... but like someone else posted... unless you are doing something cpu intensive... you wouldn't notice much difference... Let us know when u swap out how it went and if you were able to OC it more than the 4400.
As others have said you more than likely won't notice any difference. If you don't OC this chip it might even be slower unless you are running everything sans CPU at stock speeds. The only way you would notice a difference would be if you ran a benchmark, rendered, or gamed (which you would prolly get a few extra frames).
If you want to rush and break stuff sure. Open the case, move wire out the way, remove the HSF & clean it (both the old grease and the dust bunnies), pop out the chip, open the new box, fight with the plastic, grease up the new CPU, pop it in, slap on the HSF, power on, and verify bios changes which is another reboot. That doesn't even include time to re-OC assuming he plans on it.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
shit im hourly power down 10 minutes power up ten minutes do that a couple times and i made extra scratch
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
