No what I'm sayin is most 3in coils will take more power than smaller coils.
I get it now......thanks!
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
SA12 all the way
2003 Dodge Ram 1500 - Deep Orange
Build log - Blowthrought with 4 18's http://www.stevemeadedesigns.com/board/topic/122600-4-18s-in-a-dodge-ram-team-sundown-russia/
Sundown Audio SAX125.2 - Sundown PA 10"
Shok-wiring & RCA's
XS Power D6500
Mechman 320A
Sundown Audio Russia
http://sundownaudio....dex.php?/index
http://www.drive2.ru...ram/ram/skillz/ - more about my truck
http://www.youtube.com/user/Gskillz81
So what's the difference between vc sizes?
Usually with a 3" coil you get a bit more thermal power handling because the windings are spread over a larger surface area (assuming the same winding height)
There are tradeoffs though. A 3" coil has a larger former obviously and is usually heavier than a smaller coil. This gives the sub a higher moving mass and lower Fs.
A smaller coil will probably be more efficient due to weighing less, although to get the same power handling they will use a thicker gauge wire for the winding which lowers efficiency (less windings in the gap)
It's swings and roundabouts. Bigger doesn't necassarily mean better. The Atomic AP12 runs a 2.5" coil and I've fed one of them the thick end of 4kw.
10.x volts fo' life!
Also, Assuming the sundown 4 spoke basket has the same spider diameter you have to consider the different spiders. A 2.5" coil will have more spider than a 3" coil on the same basket.
-Drew
uhoh_45 said:
  • Who's Online   0 Members, 0 Anonymous, 1865 Guests (See full list)
