probably in like s3 in which they would get dominated if there are any true s3 cars there, cause an s3 car should be in the 150s+
or if they havent ever competed they could run amature class...and probably be in as3 (car off, on music, suppose to be no cussing in music)
no neither one of them have ever competed. one is running powerbass 15's (m series)on like a powebass xa 5200 or somethin small and a optima red top. and the other has 2 12" powerbass (m series) on a rockford fosgate 451s with a kinetik 1400
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
Damn thats like 4-5 hrs away bring that to BG.... It's closer LOL
taken from another post
{(Total Amperage of In-line Fusing X 10) + Woofer Cone Surface Area} = Pressure Class #
Please consult Division Rules for complete definitions.
Examples:
30 amps + 2-12 = 526 40 amps + 1-12 = 513 30 amps + 1-15 = 477 50 amps + 1-18 = 754
50 amps + 1-12^2 = 644 50 amps + 2-12 = 726 100 amps + 1-15 = 1177 100 amps + 2-18 = 1509
50 amps + 2-10^2 = 700 100 amps + 2-12 = 1226 200 amps + 2-15 = 2353 200 amps + 2-18 = 2509
50 amps + 3-10 = 736 200 amps + 2-12 = 2226 400 amps + 4-15 = 4707 400 amps + 4-18 = 5018
Fuse Requirements for Qualified Score: Fuses must have value stamped in the metal, except ATC
Permitted: AGU, AUE, ANE, ATC, ANL, or Mini-ANL (also known as MIDI); 32 volts maximum
SP - Sound Pressure Format
Measures dB inside the vehicle. 15 “Pressure Classes” in 4 Divisions
AS - Amateur Street - Basic, daily use systems. Beginners & those who have not been champions. Owns equipment. No Pro’s.
AS1 0 - 550 -- 1 Fuse Maximum
AS2 551 - 1000 -- 2 Fuses Maximum
AS3 1001 - 2000 -- 3 Fuses Maximum
S - Street - Intended for daily driven vehicles. Competitors show who can do the most with the least.
S4 2001 - 4000 -- 4 Fuses Maximum
S5 4001+ -- Fuses Not Required
M - Modified - Intended for vehicles and systems that are designed to maximize Sound Pressure level, including woofer walls and
pick-up truck cut-throughs, but are still capable of being daily drivers.
M1 0 -550 -- 1 Fuse Maximum
M2 551 - 1000 -- 2 Fuses Maximum
M3 1001 - 2000 -- 3 Fuses Maximum
M4 2001 - 4000 -- 4 Fuses Maximum
M5 4001+ -- Fuses Not Required
X - Radical X - Vehicles with major modifications; for the hard-core Sound Presssure League Competitor.
X1 0 - 4000 -- Fuses Required
X2 4001+ -- Fuses Not Required
DB - Drive-by SPL Parade Format
Measures dB outside the vehicle, in 5 “Pressure Classes”, while playing full-range music.
DB1 0 - 550 -- 1 Fuse Maximum
DB2 551 - 1000 -- 2 Fuses Maximum
DB3 1001 - 2000 -- 3 Fuses Maximum
DB4 2001 - 4000 -- 4 Fuses Maximum
DB5 4001+ -- Fuses Not Required
i likes me some audio stuff...
yea ive seen that before but its so confusing to me it looks like as2 or as3 class
Ideally, the guy with 2-12's should run a 75 amp fuse and the 2-15 competitor should run a 70 amp fuse. That'd put them in AS2. If you wanted to get squirrelly, subtract 45 amps from those numbers for AS1. You only need a second. The thing is, no batteries or anything between your fuse and amp (in order to use the low fuse rating).
I don't think my new subs won't be in yet, but I should be there with my smaller system.
Stetsom 11K2d
6-12" DC XL's
8 batts
Ohio Generator alt
2 punch 400's, 8 goldwood 6.5's, 4 selenium st200's
2010 MECA AS1 champ 146.7
Team DC I'm on the wagon, driving a wagon!
'90 Camry Wagon
155+ on music
member of MECA, FCBC, and IASCA
bump...this saturday...
cant wait im goin to be there dont know if im goin to compete yet but im goin to hook up my kinetik 1400 now in case i do
I wish this was in Bowling Green... I could make it... I am gonna try to throw together a non sanctioned show here in Lafayette for the locals... not sure when though...
well...i think he is planning a couple of more..
like another at the same location and possible another in louisville...and i think they are all 2x events..not positive though..
if not this year...come on out next year and get ya some points!
Im all set ready to go droppin no lower than 13.4 at idle with my kinetik 1400 at full tilt. Cant wait im so pumped! :clapping:
  • Who's Online   0 Members, 0 Anonymous, 2156 Guests (See full list)
