4 Ascendant SMD 18's, 36kwrms!! - teamSPB Project D*FN U...NEW UPDATES! 9kwrms PER SMD!!
Cheers for the comments guys!! Hopefully there is more to come from it yet...
The 157.2db @ 28hz sealed up with mic on screen we did was a good starting point...we now need to start playing with seat positioning, trying without the centre console, dialling in the amps some more etc etc....im pretty sure there is a 158-159db in there somewhere..just gotta find it! It may need removing the seats to find it though....however, it definately would be good to get closer to the famous 160 mark JUST off 4 18s especially considering the lowish tuning (30hz!). There may be a tenth or 2 to gain from using the external bridging modules to...however, time will tell if they help SPL scores
Stay tuned for some more videos!
ever thought of putting in a stripper pole?
R.I.P!
(Nov-29-2009)
92 explorer
current build
Has been thought about...however, the only down side is the engine is right under the seats...and doesnt have much clearance as it is...Im sure I could easily mod the centre console in order to fit the pole...but the complications lay further beneath :(
Hopefully we can sort a solution out at some point!
