hehe i consider cheap something like 30 bucks maybe? :yahoo:
i ended up getting it for 6 dollars now to get a amp wiring kit and figure out how to take my deck out so i can put the wires in if anyone on here has ever pulled the deck out of a 1990 Chevy Beretta GT any help would be apreciated
!999.5 Volkswagen Jetta
1 Planet Audio BIg Bang 15
Powerbass 1500,1
6$????? ahhahaha that´s awesome man!!! congrats...
Yea dude nice pick up
Eclipse cd7000
Thanks both of you i can't wait to get it installed but it will be a couple of weeks til i get paid have some plans on where to mount some extra speakers i will post more pictures on saturday night or sunday after i pick it up
Powerbass 1500,1
finally got pictures of the amp but the pictures i took are to dark so you can't see the them very well
here is the picture that did turn out its just the top of the amp
i have a few questions first one is there is two rca plugins one say channel a and one says channel b do i have to have rca's plugged into both my second question is there is switches by the gains one says LPF then off then HPF the other one says off and HPF what do those mean my third question is where there the power wire terminal the first one says power wire then there is a plus underneath then the next terminal says GND with a negative underneath and the third terminal says system control what do those do any help would be greatly appreciated
thanks
KCowboy620
Powerbass 1500,1
thanks
KCowboy620
for the RCA's it depends... is it a 4 channel amp? if so then YES if your going to be running all 4 channels, for the second question, the HPF is a high pass filter, it "passes" out the lower frequinces, the LPF is the oppisite, for the 3rd one, + or power wire, would be the power wire that goes from the amp to the battery, the GRD or - is the ground which goes to a bare metal spot on the car, the system control is the remote wire which runs to the headunit or stereo to turn the amp on or off
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
ok thanks for answering my questions now next week or the week after i will be able to install it but still need to get my speakers that i want but will be ones i have sitting around for now. and since if i run only two channels for now which one do i need to hook up for those
Powerbass 1500,1
  • 1 month later...
Pioneer indeed makes great amplifiers... If I was you though I would use that for mids/highs and just get another Pioneer Monoblock for a subwoofer setup. Also use HPF if you're doing mids/highs and use LPF if you're using the amplifier for subwoofers.
Team Bassick
HU: Pioneer DEH-4200UB
Front: Pioneer TS-A1683R
Rear: Pioneer TS-T110
Amp: Kicker KX600.4
Subs: PSI 18" Platform 1
Amp: Audiopipe 1500D
Electrical: Big III, Stinger SPV-40, Stock ALT
SCORE: N/A
  • Who's Online   0 Members, 0 Anonymous, 3076 Guests (See full list)
