Designing an "Octo-port"?
Give dave some time to respond, he is a busy dude, but he will normally always get back to you.
2011 Ford Ranger Sport 4.0 v6
2 sundown audio prototype nsv4 15s
crossfire 4k wired to 0.4 ohm
15 banks of maxwell 3.0 caps @ 18v
triple alts (x2 us alt 250's, x1 singer 320)
153 at 23hz
To make the end piece you lay the port on the pre-cut ring and screw it into place. Drop a router bit through a pre-drilled hole in the ring with a guide-bearing on the end of the router bit and just go around on the inside of the port. Sand it a bit after that to get rid of burn marks and you're done.
Short and skinny version anyways.
Hammerdown... 1%
I understand what you guys are saying. It just sounds so much easier than when I picture trying it. Lol. Daves ports seem to have a big flare, I just don't see howwhat he does it with only wood. Pretty intense.
you can flare it with a router bit (his doesnt have much of a flare). Just be careful about where you put the screws.
Hammerdown... 1%
pfft, too easy :P
Hammerdown... 1%
you havent lived until you've hit a screw with a router.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 2296 Guests (See full list)
