Got my Aq 2200s last night, hooked them up real quick to test them and they worked great so I unhooked it all so I could make good connections today when it was a better time to do it than midnight last night. Hooked it all up today and they are working great, still need to fine tune a bit but the only problem that I probably didn't notice last night, is that when I am idling I am getting for lack of a better term "ground noise"? maybe, its just a steady rumble from the subs and its louder the more I turn the bass knob up. If gain is 0 I either cant hear it or just barely. goes away completly when I get on the gas. it will come back a little bit if I am coasting down a road giving no gas and the rpms drop very low. like I said just at idle basically. I left my truck on for a few mins with the gain up just maybe 1/5 so i could hear it and I jiggled and checked all my rcas and grounds and no change at all. what could be causing this? where else can I look
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
Are any of your power wires touching or close to the RCA's? When I hooked up my Sundown 125.2 to test my AA mids, I got a ground noise coming through my mids. Checked all the wires and noticed my Knu power wire was in direct contact with RCA's. Ever since i cleaned up and straightened my wiring, everything has been all good.
SMD Super Seller/Buyer
Audison----Hertz----Rainbow
I will check that out Im sure something is probably pretty close together in there thanks, Ill be sure to check that out too.
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
any other suggestions? I thinks its kind of weird it stops when I rev it up does that mean anything?
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
Try grounding the headunit better maybe? Add another wire from the harness in the back to a good spot behind the HU
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
From what spot? the aluminum plate on the back of the HU? cuz the black ground wire that comes out of the back is like 16 gauge tiny wire
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
any tips on grounding my head unit or ideas of what else could cause this noise? I have never had this happen before only thing that has changed in my setup is amps.
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
your crossover may be filtering out the noise at higher frequencies.
God damn its hot today. My balls are stuck to my leg.
some amps do that. :shrug:
try with the headunit out of the dash and turned on take some wire and strip a length of it long enough to wrap around the metal part of the rca's and hold it to a grounded point and see if thats the problem if not start checkin your grounds make sure your rca's are not in contac with the power wire in any way also have your alternator checked make sure it does not have a bad diode good luck
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
  • Who's Online   0 Members, 0 Anonymous, 933 Guests (See full list)
