fuggnore Posted August 13, 2010 Report Posted August 13, 2010 okay, i had a big scare last night. i was playing some music and shit then alll the sudden my sub stopped. i was SOOOOO worried. but today i took it outa the box and discovered that the negative lead coming off the box terminal just fell off. HA what a relief. but anyway i decided to take that thing off and i just glued and screwed a peice of wood over it. i didnt really like it anyway, i would get little air leaks from were the wire goes in. the only reason i used it was so it would look a little nicer then some holes drilled with wires. but i just have my wires ran outa the port now (ghetto i know) but what would you guys recomend? just drilling two holes and running the wire out that way? 06 Honda Civic Si Sub: 15" Kicker L7 Sub Amplifier: Phoenix Gold RSd 1200.1 Head Unit: Kenwood KDC-HD545U Speakers: undecided Speaker amp: undecided Still alot more to come!!!
kl0wn Posted August 13, 2010 Report Posted August 13, 2010 If you do just drill 2 holes then run the wire out, after you run the wire out through, throw some silicone on the holes so they will be completely sealed up. Another option is to drill 2 holes, put a bolt through them and washers on each side with nuts, and connect the wire with a terminal on the inside and outside of the box. 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
bassl0va Posted August 13, 2010 Report Posted August 13, 2010 And also. If you drill a hole and run it through it might be a good idea to tie a loose knot on either side of the hole so the the wire/s can't get pulled on and damage anything. My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades.
kickass audio Posted August 13, 2010 Report Posted August 13, 2010 heres what i did. my woofer only goes up to 8 gauge. so i put 8 gauge from the amp to the woofer. and i drilled it small enough to make it really snug on the hole. if your woofer is ported then who gives a damn if the air leaks by the terminal a little bit? its not going to throw off your tuning 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
bassl0va Posted August 13, 2010 Report Posted August 13, 2010 heres what i did. my woofer only goes up to 8 gauge. so i put 8 gauge from the amp to the woofer. and i drilled it small enough to make it really snug on the hole. if your woofer is ported then who gives a damn if the air leaks by the terminal a little bit? its not going to throw off your tuning You will get hit by the farting leak if annoyance though. My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades.
raolito1980 Posted August 13, 2010 Report Posted August 13, 2010 If you do just drill 2 holes then run the wire out, after you run the wire out through, throw some silicone on the holes so they will be completely sealed up. Another option is to drill 2 holes, put a bolt through them and washers on each side with nuts, and connect the wire with a terminal on the inside and outside of the box. Mine is Option 2. Works pretty good. 2012 GMC SIerra CC System Build Headunit--Stock Sub Amp--DC 2.0k Subs--2-SA8v2's Enclosure--Need one made!! Highs Amp--Sundown SAX-100.4 Front Highs--Rockford Fosgate T2652-S Rear--Sundown Neo Pro 6.5 XS Power D2400--XS D3400 No Big Three yet! http://www.youtube.c...ser/raolito1980
kickass audio Posted August 13, 2010 Report Posted August 13, 2010 Mine is Option 2. Works pretty good. option 2 is what im going to do really soon for mine. i was just to lazy to do it lazyness is great!! haha 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
