I have a wiring question
I literally got them like a week ago.
and 2 of them I got this past friday.
do you really think they're bad?
I was hardly beating on them at all because of the break in process
dont touch the subs either while testing.. that will mess up the reading bad.
1995 Integra GSR (DB8)
Pioneer 3200-DVD
6.5 rockford fosgate 2-way fronts
6.5 rockford fosgate 3-way rear
saz-3000D
(2) 12" SA-12s
Check each sub indivicually, take it out of the box disconnect the wires,and try on ur DMM
take baby steps, u cant do it all at once unless u have a roll of 100's big enough to choke a donkey
1998 Chevy Venture "Swagger Wagon"
Kenwood Excelon KDC-X994 Headunit
3 15" Alpine Type R's in seperate T-Lines
1 RF T1500-1bd for 2 of the 15s
1 RF P1000-1bd for the single 15
3 sets of Hifonics Zeus ZXi6.5C Components( 1 more set to come for Front stage)
1 Hifonics HFi100.4 4-channel amp
Stock alt for now (DC HO SPL 400A when funds come in,currently working on buying this)
Stock battery and one Optima Redtop for now (looking at XS batteries)
3 15" Alpine Type R's (aka Swagger Wagon Build 1.0)
Swagger Wagon Build 2.0
Youtube Videos
I will tomorrow.
noob question, but will each coil read 4, or will each coil read 2 if it's a dual 4 ohm sub?
if they are dual 4 ohm sub you are gonna measure each coil separately and each coil should be 4ohms
Youtube Videos
I will tomorrow.
It should be close to 4ohm. Odds are it won't be spot on, but close.
You say 1 set per channel, what exactly do you mean? You can't do 2ohm "per set per channel"... A 4DVC sub goes down to 2ohm and if you put 2 together you either get 1ohm or 4ohm. If you put them ALL together you can get 2ohms, but on a single channel (or bridged 2 channel).
Edited by UnderLoK
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
2 270a Mechman Alts
I apologize..each subs is dual 2..Idk what I was thinking
haha no problem man, at least the subs aren't screwed up :D
Pioneer X8500
2 270a Mechman Alts
