have you checked you ICS??? Idle control censor.
Its located on the side of the throttle body. I had the same problem. I cleaned the throttle body with throttle body cleaner and the ICS with a cleaner that you can pick up at your local auto parts store. Just make sure you dont get throttle body cleaner on the ICS that caused some problems with mine
Just another idea man.
it could also be your fuel pump going bad. its a rare thing but it can happen
TRIPLE POST FAIL!!!
should i get new ones? or wrench em out and then put them back in?
Take the plugs out, put them back in, and see how the plug wires sit on the plugs. One of mine has a vaccum issue. It doesn't want to plug itself in. But just check it, then if it persists, replace both.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Definately replace them, don't put old spark plugs back in. They're around $2 a piece so might as well. I would do plugs/wires and see if the problem persists, kind of sounds like a misfire.
Pull all spark plugs out look at that little diode on each one of them see if they have arc marks, or are getting wore down. I had a problem with my truck sputtering and running like complete dung, turns out i replaced my spark plugs and everything was fine again, but that was after i added a second battery also. do you get headlight dimming and even if you dont the amp could still be drawing too much current for some stupid reason. So to sum it up check spark plugs replace if need be, and upgrade ur electrics.
Edited by cubs_fan0718
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
check your timing? maybe when you replaced the dizzy guts you moved something to advance or retard the timing?
Edited by cmamtower
apparently you dont get the fact that the subaru was wrapped around a pole. and by the status of your comment, im guessing your mouth is too.
Vehicle: 1997 Honda Civic EX
Exterior: 55w 5k Headlights and 35w 3k JDM Fogs. Lowered. Sittin on steelies right now
Amplifiers: Rockford Fosgate P450.4
Batteries: Kinetik HC 800
Electrical: Big 3 in 1/0
Enclosure: n/a : (
Headunit: Clarion VZ409
Mids/Highs: Pheonix Gold Rsd6.5's in the Front Doors
Subwoofers: n/a : (
Wire: Knukoncepts 1/0 and 4g
Future Upgrades: 20% tint all around, GC/Koni coilovers, body work (fml) lol
  • Who's Online   0 Members, 0 Anonymous, 3073 Guests (See full list)
