i dont think inverting them will change how you set the cross overs, I just dont see how it would effect your need for that. The only reason I have my sub inverted at the moment is because I have not wanted to drill holes in my pretty sealed box. When I am ready to complete it though and drilling holes for terminals so I can put it back in my boat, you better believe that bad girl will be flipped back over into a regular position.
Ty
TY
Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy
Party and Bullshit - The Notorious B.I.G.
Honest estimate on this truck when it's all done........... 172.3...........
Ehh.. U are aware of what 172.3 is, right?
yep.....:)
Two Pyle 15"s Build log
Any idea if Alpine's sound better inverted? I'm thinking about flopping my Type S's around just for kicks now.
POTATO!
Inverting a sub won't make the speaker sound any different, only change the acoustic properties of the enclosure.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
so more internal air space helps lower frequencies? my daughter's aunt wants me to demo my jeep this weekend so u wanna try to hit low as possible for this. my self built box is on hold til my collar bone is healed and my ribs stop hurten. so i'm stuck with a prefab 45hz box. if i stuff it for a while with pollyfill will that help?
Team DBs (Driven By sound)
Don't you put speaker in those enclosure things? :pardon:
most people try too! What I was trying to say was a speaker (all things being equal) will sound exactly the same inverted or not. Of course, all things won't be the same if you simply invert the subs in the same box as the net volume of your box will change. Even then, a speaker will not magically sound better if it is inverted. Of course, I am answering his question assuming when he asked if it will sound better he means that from an SQ perception and not just to mean will it be louder.
F150:
Stock :(
Processor: DSR1
so if i put poly fill and invert the subs will they hit a lil lower? not talken massive low but more of a noticeable difference. i want my first demo to be good
i want to try this rilly bad when i get my sub back from dj. dont u have to hook the sub up backwards like + to - and - to +.
Whip:2004 Ford Expedition
Headuint:Pioneer AVH-P4200DVD
Alt:MechMan 270 Amp
Big 3: Yes
Rear batts:2x Kinetik HC2400
Power Wire:carolprene 0/2 welding wire
Volt Meter:X Scorpion
Front stage:Kicker KS6502
Rear stage:Polk audio 6x8s
High Amp:Boston acoustic GT-4100
Sub stage:Audio Que HDC3 18s Copper Coils D2
Low Amp:Audiopipe AP30001D
Box:6ft3 96in2 34hz
146.8 dbs @ 35hz Sealed up
