Basically I want to stay away from using bolts on my box for speaker wire to be bridged to 1 ohm. I want it done on the sub, then 2 wires run out ot the box to the amp. Does some company make an adaptor where I can plug 2 8 gauge wires into some comtraption/connector, and that forms down to 1 to fit into a sub push terminal?
edit: btw i know i can force them in the terminal, but i'm picky and want it to look clean.. I dont like all that messy wire hanging out of the terminal...
Edited by Alex K
2006 Nissan Z Track.
My Feedback Thread
sure, here ya go
lol but seriously, just cut them down until you can fit both wires in. they couldnt make a terminal like you described because the 2 larger pieces would touch each other, or be able to rotate and risk touching.
Wise guy ehhh? Well if it comes down to trimming then i'll do that - I just wanted to see if anyone knew if a company made such a thing.
My Feedback Thread
Try T Taps or whatever they are called ..
OR
You cam use Ring terminals and connect both the 8ga wires onto a Small bolt with washers and nuts, and insert that bolt into the Sub voice coil terminal ..
Its hard to explain, but do you get what i mean?
2006 Saab 9-3 2.0T
Twist your 2 8 gauge wires together and stick in the 4 gauge side and screw it down then plug the 8 gauge side in the sub terminal
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1547193/vpcsid/0/SFV/30046
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
http://www.sonicelectronix.com/item_16847_Stinger+SPT822+-Gold-.html
Maybe something like a 4 to 8 gauge reducer. Twist the two 8 gauge wires together and insert them into the 4 gauge opening. :shrug:
Edit: Ninja'd by Eric. But, yeah, what he said.
Edited by R_Mac_1
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
OR
Yes i understand what you're saying. Could maybe do the same with a threaded rod, and small ring terminals, but like skittles said, and i nevre thought about was twisting of some sort and the 2 sides touch.
Good idea - i need to take out my sub again, for the 3rd time to see how far apart my terminals are and if that'll work. Ffs i hate taking that thing out of my car :( So fuggin heavy
My Feedback Thread
http://www.hifisound...sid/0/SFV/30046
Nice. trink40.gif You know your stuff.
2012 GMC SIerra CC
System Build
Headunit--Stock
Sub Amp--DC 2.0k
Subs--2-SA8v2's
Enclosure--Need one made!!
Highs Amp--Sundown SAX-100.4
Front Highs--Rockford Fosgate T2652-S
Rear--Sundown Neo Pro 6.5
XS Power D2400--XS D3400
No Big Three yet!
http://www.youtube.c...ser/raolito1980
yeah but if you twist them tight, and maybe use some sort of thread locker or whatever its called to keep them from coming undone
2006 Saab 9-3 2.0T
or what if i got some thin threaded rod, and cut about an inch or so off of each end of the wire, wrapped it around the rod a few times then took some solder, and torched it to the rod? there would be no way the + and - would touch.
Edited by Alex K
My Feedback Thread
