2nd Battery help
Ok so I have a 1999 Mercury Sable with a 220amp alt, i have a 4000 watt lanzar amp that I am hooking up to 2 12" lanzars. But when I am hooking up the 2nd battery in parallel I always get sparks and something melts...Help?!
"If it moves and its not suppose to use duct tape, if it doesn't move and its suppose to use WD40."
"If something broken fix it with a hammer, if a hammer cant fix it then its an electrical problem."
Teejaybee - tried it.
Skullz - the battery bolt melts... then i blow any fuse thts in the power wire...
Are any positive and negatives touching eachother
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
are you sure you put positive to positive. and not positive to negative?
2 12" memphis mojo mojo12d4
hifonics brutus bxi 2610D
1/0 power wire
4 gauge speaker wire
ddm tuning 8000k 35w hids
C&D technologies battery (100 ah)
custom box tuned to around 45hz(designed buy fritosaregood)
2010 kia forte koup
sounds like the positive wire is definitely grounding out somewhere..
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
well i only use red for pos n brown for ground... n it doest work even if i take the battery n put it on the ground next to the front one and run the wires accordingly.
Sounds like there could be something wrong with your second battery then. What happens when you put a voltmeter to it? Obviously red + black - then do you get 12.x volts or -12.x volts? It would be weird if that was the problem but possible I guess
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
