MarioB Posted August 31, 2010 Report Posted August 31, 2010 i have a question about my fuses i have in my car my wires are all 1/0ga. 1st question On my big 3 upgrade the wire from alt to battery i have a 250 amp fuse. should it be 300amp? 2nd question From my rear batteries to my 2 kicker 2500.1 amps i have a 200amp fuse should i use a 300amp fuse on these runs also? does it really make that much of a difference i havent blew no fuses yet but if it helps for them to be bigger ill change them out 12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodcsoundlab.com Quality is all in how you take pictures I have plenty of projects that look WAY better on camera then in person crazy to fit so many in so little. Reminds me of some of the porns I've seen?
memphisBred Posted August 31, 2010 Report Posted August 31, 2010 For the run to your kicker amp use a fuse that is equal to the fusing on the amp. On the alt to battery run I used a 300a fuse for 1/0. It's not going to help anything as far as performance, it just is better to use fuses, of the right size, for different sized wires. EX: If your amp has 4 50a fuses use a 200a fuse. SMD Super Seller/Buyer Audison----Hertz----Rainbow
Robert8252 Posted August 31, 2010 Report Posted August 31, 2010 What you have sounds good and if they aren't blowing I would not go bigger. Your fuses sound right for what you're running so just leave it. You don't want a much bigger fuse then the amps you're pulling other wise you lose the safety feature of fuses because damage will happen before the fuse pops 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
MarioB Posted August 31, 2010 Author Report Posted August 31, 2010 What you have sounds good and if they aren't blowing I would not go bigger. Your fuses sound right for what you're running so just leave it. You don't want a much bigger fuse then the amps you're pulling other wise you lose the safety feature of fuses because damage will happen before the fuse pops the manual suggusted 300amp fuse for amps the do not have fuses on them its self. 12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodcsoundlab.com Quality is all in how you take pictures I have plenty of projects that look WAY better on camera then in person crazy to fit so many in so little. Reminds me of some of the porns I've seen?
MarioB Posted August 31, 2010 Author Report Posted August 31, 2010 For the run to your kicker amp use a fuse that is equal to the fusing on the amp. On the alt to battery run I used a 300a fuse for 1/0. It's not going to help anything as far as performance, it just is better to use fuses, of the right size, for different sized wires. EX: If your amp has 4 50a fuses use a 200a fuse. the amps do not have fuses on them. and ill upgrade my fuses when i get a couple extra $$$$$ 12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodcsoundlab.com Quality is all in how you take pictures I have plenty of projects that look WAY better on camera then in person crazy to fit so many in so little. Reminds me of some of the porns I've seen?
