Typically firing the ports to the rear is louder unless you have a trunk and seal your enclosure off firing forward..Its not always the case but typically the port forward is not as loud
Team MaxRetribution
Si Vis Pacem Parabellum
because we tested port forward and it is rarely the best option.
is the difference really gonna be that drastic? And is port forward atleast better than port back with no space between the port and the back hatch?
choking the port against a wall is a horrible idea so you are correct in staying away from doing it. can you do port and sub up? or maybe make the box taller but not as deep so you can fire the port back?
yes, it does make a big difference but if its all you can do then its all you can do.
I can, absoultely. However, I heard that if you do port up, than bending the port is a bad idea. Is that true? If not than Im good to go.
Subs back or up with port to side is pretty loud in a trunk. Also in SUV's from my testing. Gives you a good solid wall that wont lose energy compared to the trunk hatch itself where you could loose TONS of energy. Side port firing from my testing also gives you SOLID lows ;)
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
I have s 15" XL firing into the cabin in my Grand Am......It is better than it was firing toward the trunk lid, since the box just barely fits in the trunk(had to take off tail lights to get it to fit...)so it was blocking the majority of the air coming into the cabin, so I 180'd the box and made a trim panel to seal it off from the trunk, and now its louder...
¿ǝɯɐƃ ǝɥʇ
