sorry for a dumb question, but i'm gonna be gettin 4 fully loaded 15" BTL's. i understand ohms and what they do, but what kinda gets me (and i dno why) are the ohms on subs. what's the difference of a 1 ohm sub and a 2 ohm sub as far as putting power to em? i'm most likely gonna get a pair of 4k watt amps hooked at 2 ohms to power em. question is should i get 1 ohm model? or 2 ohm for the most out of my amp? or should i get the universal model to change it? will possibly change to 1 ohm for comps, or if they can just handle the power period. thanks :)
different ohm loads offer different wiring options. to get the most out of them T4ks get dual 1 ohm and wire 2 per T4k to 1 ohm mono.
NoFearX18 said:
trainman0978 said:
Well,you need atleast 2000wrms apiece to each btl for em to shine,so what are the amps in question?Can you also tell me what your electrical is like?Just with the info provided,the BL line might be better suited for you instead of going straight to the flagship of Fi
amps are either memphis mojo or rockford t40001. electrical...200 amp H/O alt, got extra batteries, but gonna upgrade em soon anyways
get dual 2's and parallel each woofer to 1 ohm then series back up to 2 ohms, or get dual ones and paralellel each woofer to .5 and series them back to 1.
this is for only 2 woofers, the other 2 will have to be done say way and hooked to different amp.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
If you're going to run 1 amp to each pair of subs get dual 1ohm coils,series wire the coils then parallel wire the subs together.Repeat this for the other amp and subs.This will give you a total nominal load of 1ohm per amp.
Edited by Earthman
i judt said that lol.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
I've been wondering whats the max on a btl
"IT SOUNDS SLOW MOTION AND STUTTERING"~~~~LOL
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Powermaster S3400 & D3100
Iraggi 300a alt
SecondSkin - totally dead
Knu wire
  • Who's Online   0 Members, 0 Anonymous, 520 Guests (See full list)
