SMD/LVL 5 Warhorse F150. 10/18 new XS POWER
does the person need to go and spend another $5-$6k on amps batteries and power wire just to hit the same number as what the other subs were doing only to reach thats subwoofers "limit" as well? doesnt make a damn bit of sense to me
VERY good point
:popcorn: still waiting for those numberz
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
Im gonna stir the pot here a bit. I just got 2 DC 8s ordered that will ship today with the level 5s. Should I give them 10k and see what they will do too....haha i can just see them blowing up right now. But for real they should do nice for midbass in the center console (when I get around to building it). But for the mean time they are going in the trunk of a 2009 nissan maxima on a JL 1000.1
Now on to those of yall who are bitching about the test being unfair because the LVL 5 is 2000 RMS and the SMD is 3500 RMS and that it isnt fair because one will being pushed harder and closer to its limit than the other. I have a very easy way to solve this issue. Here is where the true beauty of the Warhorse comes out. I can adjust the power output anywhere from 1000w all the way up to 10000w in 500w increments. So be fair, each sub will be tested as its RMS power handling. Then just for fun tested at 5k per sub and see which gains more.
Just figured that should give yall more to argue over.
Didnt get picture proof (camera went dead) but the SMDs in the current box (15.74cuft 12cuft after displacements). Did a 149.91 legal this morning.
I just got a line driver so I am about to install it and see what difference there is going from 2v preouts from my HU up to 5-7. More to come later.
since even more people are going to say "that still wont be pushing the smd.." put around 6-7k on 1 smd to let it shine.. then it will being pushed to its and 5k on dc lvl 5.. see what happens.. should be interesting.. just one sub in one box both being pushed to their limits.. :popcorn:
only 2v preouts...? WOW man hook up that line driver asap
i can guarantee there are some pro audio guys that would laugh at this statement
but thats just it
why did you buy DC lvl 5 subwoofers when you could have got some pro-audio woofers and run half the rms power?
could you attain the same number? yes. will it be the same? no
get it yet?
please Nick (Fi Nick, forgot Chode is Nick too) correct me if i am wrong as i dont want to put words in your mouth.
it looks to me that the SMD woofer was made for a new generation, that loves power. as class d technology advances and power becomes cheaper to make, people will naturally want to use that available power. so if the amount of available power goes up but the amount of space in vehicles remains relatively the same.. that means something must change in a woofer. da da da da! SMD
the way i see it is this: the lvl 5, through years of testing research yadda yadda, it has begun to flirt with the limits of this generation of woofer.
the next generation of woofer is like the SMD. naturally since the SMD is the first of that generation it will inevitably be the worst.
what is being debated here is an overlapping of the two generations. two seemingly similar woofers that have totally different DNA.
ask any old fart on here (sorry guys :lol: ) and they will tell you about some low power woofer that was the shit back in its day. thats how things work. availability increases so consumption must increase also (in this case: available power vs. rms handling)
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
in my defense i never once said one subwoofer is better than the other...i just said for his case i would like to see which would best suit his application
and did i?
nope... :shrug:
Johns.jpgSuburban Coming Soon
Line driver installed and run up to 5 volts. This made a big difference. I will post a pic of the TL screen later but when I tested this morning its was a 149.16 at 40hz with 14.6 volts. The test I just did with the line driver installed was a 149.76 at 40hz with 13.7 volts. Big difference for one small change. I will play with the line driver later and see if my amp goes into protect with anything over 5 volts.
nice scores what was the clamped power?
