i did the big 3 in 4 gauge wire. (for now) until i get 0 gauge. when i did it, i hooked my engine ground to my negative terminal on the battery.
is that bad?
cuz ive seen that its supposed to go
engine to chassis, but isnt the negative pretty much a ground anyway?
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
4 DC XL's W/ PSI Recones
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
Mechman 220a Alternator
you have it right...
alt + to battery +
engine ground to battery -
frame/strut tower to battery -
kranny the fuck is up with you and the situation ?
R.I.P!
(Nov-29-2009)
92 explorer
current build
As long as the negative battery terminal goes to a good ground it's fine. That's how a lot of car are actually wired stock. Engine block to battery - to ground.
i have all the stock wiring still hooked up as well, i just added the 4 gauge
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
thats perfect. current will take the path of least resistance. you are not replacing the factory wiring. You are buffering it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
One ground goes from the battery to the chasis and one goes from the battery to the engine block!
Kenwood Excelon KDX-693 Head Unit
Kinetik HC600
Powerbass 6.75's in front doors
Powerbass 6.75's in rear deck
Powerbass 1000.1D
Powerbass 400.4
2 SA-12 inch Sundown Audio Subs
0 gauge Power Wire and Big 3
Custom Amp Rack
Code Alarm with remote start
Stinger Digital Volt Meter
My build log http://www.stevemeadedesigns.com/board/topic/51869-1996-chevy-blazer-build/
My youtube channel http://www.youtube.com/user/kanesdisciple
how much power do you plan on running? because 4 gauge for your big 3 will be more than enough for plenty of current due to it being so short. I have also heard of people burning the + terminal of their alternator using 0 gauge wire because of the small resistance in the wire, and the higher resistance in the terminal. Terminal heats up and damages the alt.
Orion 2500D, Jbl Gto 75.4
Team Wolfpack Audio FSQ 15" d2, mb quart xover, tweets peerless 6.5 mids
Alpine cda-105
optima up front Knu klm 1/0
