michigancapri92 Posted September 16, 2010 Report Posted September 16, 2010 Friend had trouble with car fusing blowing we thought it was wire so we replaced both power and ground wires ... the car turns on no problem cap is reading 14.4 volts then we turn of car and plug in remote wire turn car back on ... fuse is dead. What could it be?? Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
Hugh G. Rection Posted September 17, 2010 Report Posted September 17, 2010 Friend had trouble with car fusing blowing we thought it was wire so we replaced both power and ground wires ... the car turns on no problem cap is reading 14.4 volts then we turn of car and plug in remote wire turn car back on ... fuse is dead. What could it be?? probably something in the amp has killed over, and the protection relay is frozen. Owner of BigAss Ports
EclipseChris Posted September 17, 2010 Report Posted September 17, 2010 Post setup. i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback.
michigancapri92 Posted September 17, 2010 Author Report Posted September 17, 2010 We have used a diff amp and same thing happened could it be something behind the radio or the remote wire Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
EclipseChris Posted September 17, 2010 Report Posted September 17, 2010 We have used a diff amp and same thing happened could it be something behind the radio or the remote wire Check it with a meter. i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback.
michigancapri92 Posted September 17, 2010 Author Report Posted September 17, 2010 Post setup. ??? What do you mean post setup Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
michigancapri92 Posted September 17, 2010 Author Report Posted September 17, 2010 Check it with a meter. Check what with meter?? Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
EclipseChris Posted September 17, 2010 Report Posted September 17, 2010 ??? What do you mean post setup Post the setup. HU Amp wiring etc Check what with meter?? Voltage at amp to the remote and constant while playing and not while playing. i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback.
TeamHT Posted September 17, 2010 Report Posted September 17, 2010 How big is the fuse and how much current would the amp be drawing? Tell me...does this smell like chloroform to you?
