Biggest speaker wire for XL
If this is for your wall I suggest you do the nut and bolt terminals like flashlight said. That way you can switch up impedences without taking the subs out and you can use 8ga with no problem
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
I like the wiring from the outside idea, but I am fucking retarded when it comes to speaker wiring, series, parallel, ohm load. Just can't grasp ohm's law. Maybe someone could show me how to wire up to the bolts, then from the bolts to the subs. 3 dual 1.4s xl's. Looking to get close to 1 ohm as possible.
Edit: Thanks for answering the original question Boilermaker.
SMD Super Seller
My Feedback Thread
i always like the terminals on my solo-x's. you could screw the push terminal off, put whatever size wire in a ring terminal, then use the push terminal as a nut to hold it on.
Owner of BigAss Ports
  • Who's Online   0 Members, 0 Anonymous, 902 Guests (See full list)
