didnt think of that but thats a good idea if you dont want to cut wires
run new main wires (12v+, ACC, and Ground) then you have the existing stuff untouched and always have the option
ty
TY
Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy
Party and Bullshit - The Notorious B.I.G.
Honest estimate on this truck when it's all done........... 172.3...........
Ehh.. U are aware of what 172.3 is, right?
yep.....:)
Two Pyle 15"s Build log
run new main wires (12v+, ACC, and Ground) to where? I can't figure out which is which
Run new wires from the new deck. run your constant 12v to the battery, switched 12v to the ignition or fusebox, and ground the...ground. then run new speaker wire to the speakers.
But if you really want to hack the factory wiring apart, find the plug that goes where the "1234" is on the pic. 1 is your factory ground ( I'd suggest NOT using this ground though, just ground to some metal behind the dash) 2 is your switched 12v/ignition wire, 3 is illumination/dimmer (if the new deck has it)and 4 is your constant 12v.
#5 would be the power antenna, 6 is the speaker wires, but I'd just run new wire personally.
So, really, I'd say just rewire all of it. That way you are 100% positive it will work. lol Good luck!
Don't use the existing wires run new ones to be safe as most older cars back then shared ground wires so it would be pointless in using the factory wires.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Thank you everyone. I found it easier to run the newer wires directly. I also disconnected the speaker wire harness from the stock volume knob and reran it behind the head unit and connected the corresponding wires.
The reason I ran the wires direct is because I figured out how to connect the wires with the stock wires but the battery died in the process of doing this and when I recharged the battery the battery wire had no current, only the ignition wire did. Old cars suck LOL
  • Who's Online   0 Members, 0 Anonymous, 482 Guests (See full list)
