Mayo Posted September 24, 2010 Report Posted September 24, 2010 Hello everyone. I received some great recommendations and feedback as I was trying to decide on which direction to go with my new set-up. I decided to go with the Audison Bit One, LRx 5.1 and ML2500 x 2. I just recently replaced my front and rear 2-ways with Focal 165 V30s. James was quite helpful with his feedback but he recommended going with two amps (2.9 and 4.5). A local shop called Xtreme Vehicle Designs will do the install. Both doors and trunk will be fully dynamatted. Any feedback is appreciated. Thanks. http://www.audison.e...?Section=BITONE http://www.audison.e...?Section=LRX51k http://www.hertzaudi.../default_en.htm http://www.focal-ame...eakers/165-v30/
AI James Posted September 24, 2010 Report Posted September 24, 2010 if your going 2 way. then id say just do the 5.1k just depends on if want your subs playing off ab power or d the 5.1k will give the milles more what they like then the 2.9
memphisBred Posted September 24, 2010 Report Posted September 24, 2010 This should be nice. The bit-one is so sexy. Off topic... James I noticed you have the JBL now and the bit-one out of your sig. Are you going to be selling it? SMD Super Seller/Buyer Audison----Hertz----Rainbow
Mayo Posted September 24, 2010 Author Report Posted September 24, 2010 This should be nice. The bit-one is so sexy. Off topic... James I noticed you have the JBL now and the bit-one out of your sig. Are you going to be selling it? Cool. Many thanks for the feedback James and Bred.
jbondox Posted September 24, 2010 Report Posted September 24, 2010 or just do the first with the 2500's on the d of the 5.1k, front focal midbass to the B and tweeter to the A. Leave the rears to run off something else, doesn't have to be anything crazy normal system set up that i do here is the above but with Mille components SMD SuperSeller VerifiedJbondoXJames Shields
Ray Posted September 24, 2010 Report Posted September 24, 2010 MILLE or MLK JIM?? mlk's active on the 5.1 is a pretty sweet setup. And to the OP Just make sure you run nice huge power wire to the 5.1 and scope the signal The amp sucks current, and dislikes any clipping. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Mayo Posted September 24, 2010 Author Report Posted September 24, 2010 This should be nice. The bit-one is so sexy. Off topic... James I noticed you have the JBL now and the bit-one out of your sig. Are you going to be selling it? or just do the first with the 2500's on the d of the 5.1k, front focal midbass to the B and tweeter to the A. Leave the rears to run off something else, doesn't have to be anything crazy normal system set up that i do here is the above but with Mille components I'm confused. I thought the 5.1 would handle both pair of the 2-ways AND the two Mille 2500s?
AI James Posted September 24, 2010 Report Posted September 24, 2010 the 5.1k is 50x2 160x2 1090x1 so with the equipment your running id go active on the comps up front using the 50's for tweets and the 160s for the mids and 1090 for the 2 subs at a 2ohm load id even scrap the rears all together and put the money towards a bitone.
jbondox Posted September 24, 2010 Report Posted September 24, 2010 what James said... though the last 2 I did with Alpine screens, I used the mille MLK2 crossovers bi-amped with all tone controls set to 0 and no crossovers on the deck. used the mille x-over with it's built in time alignment... the sub was set to 70 on the d channels, the b channels were at 50hz highpass, and the A channels were at 500 i think so as not to toss the signals out of phase mlk is mille SMD SuperSeller VerifiedJbondoXJames Shields
Mayo Posted September 25, 2010 Author Report Posted September 25, 2010 the 5.1k is 50x2 160x2 1090x1 so with the equipment your running id go active on the comps up front using the 50's for tweets and the 160s for the mids and 1090 for the 2 subs at a 2ohm load id even scrap the rears all together and put the money towards a bitone. Can't scrap the Focal s because they were already purchased and installed last month. All that's left is installing and setting up the 5.1, Mille's and Bit One.
