I was wondering before i decided on what amp i wanted to buy, could my BTL take 2600 RMS daily? i am debating on what i want to do, i want to buy a AQ2200d and then again i want to get a AQ3500.1 because i will eventually upgrade to 2 BTL 18s or i could get another AQ2200d and strap them, i dunno what to do, anyone got some ideas?
02 Dodge Durango
1 Fi SP4 18" .v2
Sundown SCV3k @.5 Ohms
XS D3100 up front
Northstar SMS AGM 400 in the back
All XS Power 0ga OFC
240a Apex h/o alternator
Pioneer AVH-X2500BT HU
Dual 0ga runs from the alt to battery
Dual 0ga runs from battery to amp
Yes it can take it just make sure you have your gains set right nad not clip them and you'll be set man those things are known to take 4000 if set right man
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
Yes, it can take 2.6kwrms. As Beanz said, easy with the gains. Also, don't make the box gigantic
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
yeah imma make the box 4.5 cubes at prolly 34Hz the one its in now is 10 cubes at 32, way to big for 1, haven't built the other one yet
02 Dodge Durango
1 Fi SP4 18" .v2
XS D3100 up front
You can get away with a BTL on a AQ 2200 (never seen one put out 2600) in a 10 cube box lol seen it done, and worked pretty good. Got his 150 on 2k clamped watts at 42hz.
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
4.5 cubes? Try doubling that. Did you mean to type 15" BTL?
LMFAO so true
:blush:
i ran my 18 btl in 5.75 cubes on 3k i couldent move the sub enough to cool it.. i ran 6k to it ( 2 audiopipe 3ks at 1 ohm ) and it got warmer on 3k then it did on 6...
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Nahh nahh I said 18 (eighteen) BTL, 4.5 cubes is small, BUT that monster will get nasty if I tune the amp right, if not, imma have to order a recone >.<
Here's what Scott said...
It will get loud.  Definitely make sure that your subsonic filter is set 2-4 Hz below tuning and that you do not have the bass boost on with the amp or the headunit.  Setting things up correct will definitely help the subs life expectancy.
Edited by Krazykid122
02 Dodge Durango
1 Fi SP4 18" .v2
XS D3100 up front
I was happy with every enclosure I used with my BTLs in the 5-8 ft range, but once I went down around 4.5 I had issues for daily use. Stick to the 5+ft recommendations and you should be fine.
With the power you're using I'd lean towards a larger box.
tejcurrent
XS Power
T3
