DC Sound Lab
I understand were you are coming from if you are like me i get use to it very fast. ive changed my setup 7-8 times this year alone from kicker hifonics dd to dc. if you get your box right on then you can play with alternators,batteries, vcms,wire bussbars, deadening,then highend soeakers amps etc. its neverending believe me. i thought i would never be happy but once you star hitting low 154s like i am its enough for daily. to be honest i cant roll around with my shit full tilt. it makes me see double, and gives me a migraine after 20 min. and ive been in some loud cars.i usually have my bass knob down and enjopy my highs. as far as port up thats your only option. have you thought about going with 3 woofers? bet it would be louder than 4, and you could do rear port
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Tearing the car apart with 11k? and without proper electrical highly doubt you're doing anywhere close to the rms. and something was said earlier that stood out to me, you don't want to dampen or upgrade the electrical to see what performance you get with the enclosure itself? these upgrades are what allow you to use an enclosure to its fullest capability. you're losing performance without these upgrades and therefore not seeing proper performance of your enclosure.
my personal opinion, don't go all out in one aspect only to halfass it another.
  • 2 months later...
i got the box built built for 4 running 3 right now each sub seeing ~7 cubes port at 12 per. it sounds pretty damn good. tl it legal at 151.2 @36hz, 151.1 34-39hz, 148.6 @ 29hz (wondering now if its dropping from my subsonic filter) burping one after another. subs not heating up.
cant wait to recone that last one to drop my load.
  • 1 month later...
do the big 3...i bet youll gain just by doing that...and it may keep you from burning up your factory ground wire
NoFearX18 said:
trainman0978 said:
Im just wondering, do you guys even run your subs through design programs? i know some of you guys have 18"s as 30 hz which is good, but if you put the numbers down in design you play at like -5db@30 hz. Just a little curious if you guys even take the extra step to ACTUALLY design a box. not trying to thread jack or bash.
Also, if you find the specs on the lvl 5 i would love to have them to put in a BBP file. qes, qts, qms, fs, vas, so forth : )
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
Starting fs of the 5s is like 70 hz iirc.
After break in it drops to 33 if I'm not mistaken. I could be wrong. As far as the others I'm not sure.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
i heard the same somewhere
NoFearX18 said:
trainman0978 said:
I thought the level was more for SPL?
the Level 5? it can be...its also a very musical daily driving subwoofer
NoFearX18 said:
trainman0978 said:
  • Who's Online   0 Members, 0 Anonymous, 995 Guests (See full list)
