NEW BOX FINISHED! 30hz NEW PICTURES AND FLEX VIDEOS! Opinions?
gbsx
good job building it, 2 questions/statements
  • fill all the wood with a bondo type filler, before you paint so it looks completely uniform
  • why all the white caulk? do you not believe that with a large port that the air will take the path of lest resistance? and with a properly glued joint, it makes a great seal...
1. I painted everything because I had the gun out and wanted to do the inside of the box as well and with that gun it was hard to not just do the outside as well it had a wide spray to it. So I just did everything. I will be countersinking all the other screws I have and doing bondo then re-painting with a couple coats and then some clear coat.
2. On my first box I did glue on all of my joints and screwed everything down as well as clamping everything well I was screwing everything together and letting the glue dry. It sounded fine but then a friend and I went in a used caulking on all of the edges and it sounded dramatically different in a good way so I'm just doing it on this one as well before hand. If I don't like it then I'll build another box. I get MDF at $15 a sheet and this box only took about 60% of one sheet.
1989 E30 325i BMW (New Car)
iPad 64GB 3G (COMING SOON!)
1 12" DC LEVEL 4 w/LEVEL 5 Soft Parts
Ported box - 1.5 Cubes tuned to 33hz
Sound Stream STL1.1200D
4 Gauge Stinger Wire (+ & -)
8 Gauge Amp to Sub Stinger Wire
Tsunami Mini ANL 130 Amp Fuse
AUDIO WRAP SUPPORTER!
damn, great job dude, i wish i had a whole woodshop to use, my boxes would be amazing. hell, i'd settle for a panel saw!
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Great looking box you have there!
Thank you! I'm quite happy with how its coming along so far.
Yea it makes an incredible difference. I could have never done anything like this with the tools I own.
was that latex caulking or 100% silicone. it looks like latex adhesive. that stuff doesnt dry.good craftmenship on the overall box tho. I use fiber glass resin on all my enclosures it justs fills in all the gaps and the porus mdf and makes it smooth as glass i think it helps with air flow
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Looks good.
You say you put the screws in after the glue dried? The point of screws is to pull the glue joint as tight as possible before it dries. Not really much point in putting them in after. They won't really make the box any stronger...may even weaken the joints.
I would have done that but I didn't have any fiber glass. Maybe next box. I do want to try that.
Looks good.
No I screwed the screws directly after I set the top on with the fresh glue.
  • 3 weeks later...
New pictures and a few videos. Finished with box finally!! I'm loving it. It's tuned to 30hz. Damn does it move alot more air. I'm loving the wider port as well. My first box's port was like 1.5" wide, it sucked. Anyways, enjoy. I took alot. It didn't end up looking as pretty but who cares it's already sold and I'm moving it on out as well as the Type R this week hopefully. Doing a quarter wall in the backseat with a DC Level 4 18" w/Level 5 Coils FTMFW!
Directly After first Clear Coat
Continued on Next page
Old Shitty Box - 1.6 cubes tuned to like 40hz after i fucked up.
New box 1.8 Cubes 45 degree corners, clear coat, awesome paint, 30hz MUCH BETTER!!
VIDEOS:
Enjoy! Comments and opinions greatly appreciated! Tell me what I can improve on or what I shouldn't have done. Thank you!!
-GBS
Already off the top list? No love tonight?
