Planning on building a new box before the end of the year, but i'm not sure with what material i should use.
ill be building roughly a 100 litre ported box. and want to get the most out of the sub.
last box sort of failed as the wood was under too much pressure because it was a very small sealed box.
wish to avoid this problem second time round.
Any advice you can give me will be much appreciated.
Thanks
:D
Honda Accord SirT + Mad sounds = Awesomeness
VTEC go BRAAAAAPPPP :P
http://www.stevemeadedesigns.com/board/topic/141261-99-accord-sirt-sq-build/
Alright well i never done the big 3 so i see in my vision my truck on fire...
3/4" mdf, screws, nails, wood glue, clamps, silicone, threaded rod, fiberglass/resin, etc.
2006 Nissan Z Track.
My Feedback Thread
Thanks
:D
most cost effective is probably gonna be mdf.
Owner of BigAss Ports
no silicone. make the cuts right and glue is all it takes to seal the enclosure.
hugh g. rection has the right idea. glue and wood. :)
2 12" memphis mojo mojo12d4
hifonics brutus bxi 2610D
1/0 power wire
4 gauge speaker wire
ddm tuning 8000k 35w hids
C&D technologies battery (100 ah)
custom box tuned to around 45hz(designed buy fritosaregood)
2010 kia forte koup
Silicones what, 3 bucks? Why not just do it anyway. Why don't we just start saying "dont fiberglass that wall for 4 18's. Braces, glue and screws will hold it just fine". Sure it will, but why not just take the extra step and make it that much better.
My Feedback Thread
liquid nail. not glue
explain
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 817 Guests (See full list)
