its two audio que hdc3 18s dual 2 ohm. each of them are hooked two one channal the amp reading 1.2 ohms. with them specs of the box dose it seam like there is too much port area. i dont think the subs are out of phase but the cones do move at differant speeds. one of the is the new aq hdc3 with the mesh in between the rizers. and the other one is the old one where you can see the coil.
Whip:2004 Ford Expedition
Headuint:Pioneer AVH-P4200DVD
Alt:MechMan 270 Amp
Big 3: Yes
Rear batts:2x Kinetik HC2400
Power Wire:carolprene 0/2 welding wire
Volt Meter:X Scorpion
Front stage:Kicker KS6502
Rear stage:Polk audio 6x8s
High Amp:Boston acoustic GT-4100
Sub stage:Audio Que HDC3 18s Copper Coils D2
Low Amp:Audiopipe AP30001D
Box:6ft3 96in2 34hz
146.8 dbs @ 35hz Sealed up
what i was trying to ask was if there is to much port area. i was riped when i wrote it.
Alt:MechMan 270 Amp
Big 3: Yes
Box:6ft3 96in2 34hz
cool statement bro. is there a question here?
obviously the question is "how do you spell 'rilly'?"
and "pikey" "dose" "differant" and "rizes"
Edited by skittlesRgood
WTFAMIREADING.JPG?1269222305
I'd double check wiring on EVERYTHING. Your ohm loads, make sure your subs are in phase, make sure the gain is set properly (at least with a DMM) and that the high pass isn't above 80 (i put it at 65-ish but 80 should be the maximum). Also, the tuning of your box will affect the notes. Making the port smaller will tune the box LOWER, not higher. So if you're concerned about hitting notes in the 50-80 hz range and your subs wont do it, either re-do the box or get some midbass speakers.
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
:trippy: I couldn't make sense of anything he said rilly
did you make your box, maybe built it wrong or tuning is off :shrug:
An Audio Technix 18" Strato on a Kicker KX120.2
My Youtube Bass Vids
Updates When Possible...
I've bought from JBurt09, OrionStang, bcpballer64, LoudNLow931, audioman21, and CJ18 from here (as refs)
can u post a pic of the setup... One thing that might be going on, some vehicles change the tuning of the box... also, do you have another amp in there, possibly mids and highs and the highpass is set low as the low pass on the sub amp? (a shot in the dark, BUT possible)
Edited by techforce
