Team Droppin Hz Tahoe Build
yea looks sweet. no pods in doors? im sure your doing kicks. all that low end is going to drown those highs, i know from experience. lol
HAHA.....No worries. Theres 4 diamond audio Hex comp sets going in. Now 1 in the front doors, 1 in the kick and i in the rear door. Will be working on lower half front doors for 2 sets in there. There will also be midbass somewhere as well.
did you wrap the upper inserts? how did you get them off ? i need to do mine, mine look like they were inserted with a tab then melted in the back. di you just grind it off?
you dont take them off. Its apain in the ass to do them. there are links on fullsizechevy.com and gmfullsize.com
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
thats why i left mine alone lol. plus the curves on it would be a bitch to wrap if you couldnt stretch it. and the insert is carboard i assume. jeff are youn going to put any of the rear panels back in? or you making some custom ones
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
you dont take it off at all ;)
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
lol figured that. no way to fasten it back on unless you use some super high strengh adhesive etc. its better left stock
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
you seen cj's build log of that f150 with the warhorse?
you could "borrow" the idea that he came up with of the custom center console with the tweeters and all and the mid bass down at the bottom..
i dont know if youve seen it or not but it was bad ass. and you could wrap it in some blue suede or some of that leathery stuff steve got his box wrapped in.. just a idea or two..
