yeah it can only be ran with dual alts
You can run it on Stock alt only, does not need to be dual alts. You would just have a spare plug for when you do go with dual alt setup but it has to be a GM alt since the plug is GM plug.
This module is for a ford stock alternator and a gm oval 4 plug dual alternator ad244 style
Same as mine
If you are running only a stock ford Alt the you only need the wires with no plug
If you have a 3g or 6g alt the plug should look like this and you splice the two MLA wires into the big Yellow wire on the 3g or 6g Alternator
If you have a 4g Alternator you splice the two MLA wires into the Orange wire with blue stripe.
