juggernaut405 Posted October 18, 2010 Report Share Posted October 18, 2010 Going off factory cd player. Have everything hooked up correctly or so I believe. Well ran remote wire to the fuse box with the fuse for the audio system/ onstar and the amp powered on. but when I hopped out the truck to go to the back of truck I tripped over remote wire n it snapped n I blew the fuse .well I replaced the burnt fuse n remote wire and amp powered on once again, but this time as I was hiding the remote wire the amp cut off and I haven't been able to get it to power on since. The internals of amp look fine so I know it's not blown. So what could my problem be ? Quote JUGGERNAUT DA ASSO Link to comment Share on other sites More sharing options...
Freshman6969 Posted October 18, 2010 Report Share Posted October 18, 2010 lolwut? you lost me......but uhhh check your grounds? and see if the wires pinched Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
Alex K Posted October 18, 2010 Report Share Posted October 18, 2010 last time i checked the remote wire was a positive wire. You were running that wire near the chassis of the car while the amp was turned on. You could shorted the wire and blew a fuse on the amp. Check the amp? Quote 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something. Link to comment Share on other sites More sharing options...
byers319 Posted October 18, 2010 Report Share Posted October 18, 2010 Why don't you hook up your remote to your hu? Did you check the fuses in your juse box that its on, the amp fuses, and the power wire fuse? Quote Link to comment Share on other sites More sharing options...
korey_hofer Posted October 18, 2010 Report Share Posted October 18, 2010 did you wire switch right? Quote previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street. Link to comment Share on other sites More sharing options...
kjj913 Posted October 18, 2010 Report Share Posted October 18, 2010 thats what i would do. put your remote wire to youe head unit. and possible when you were hiding it maybe if you movied somehting it could have pinched the wire causing it to short out? also if you blew a fuse on your remote wire. maybe you could have blew the fuse on your 12v also? Quote Veng. Link to comment Share on other sites More sharing options...
Autruche Posted October 18, 2010 Report Share Posted October 18, 2010 do you have a DMM? if so, set it to check impedance and put a probe on each end of your remote wire if you can. That will tell you if there's a break in the remote line, which will help you narrow it down. or just put it to volts dc and test the remote wire at the amp for power. Even doing something like taking out your dome light bulb and seeing if you can get it to turn on with the remote wire would work. Quote Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want Link to comment Share on other sites More sharing options...
juggernaut405 Posted October 18, 2010 Author Report Share Posted October 18, 2010 I have jus factory hu so what would I splice the remote wire with Quote JUGGERNAUT DA ASSO Link to comment Share on other sites More sharing options...
juggernaut405 Posted October 18, 2010 Author Report Share Posted October 18, 2010 Amp the rf t1500 didn't see any fuses on it Quote JUGGERNAUT DA ASSO Link to comment Share on other sites More sharing options...
RMac18 Posted October 18, 2010 Report Share Posted October 18, 2010 I'd check the remote wire for sure, sounds like it's shorting somewhere. I did the same thing kind of once, had it all working then when I put the interior back together I pinched the remote and grounded it out and the amp wouldn't turn on. So check that first. Quote Link to comment Share on other sites More sharing options...
