I had 5 visoniks, blew up three of them...so I subed the stetsum. The two visoniks put out more power than the stetsum, had to turn them down alot..Plan on getting them fixed for next year.
You might be able to build a box, but this tells me you need to research more. Gain is not a volume, you don't just 'turn them down'.
10501650_10203332501847103_1859383749711
Blown
reserch...hhmmm gain go up gain go down....turn gain down on visoniks to match speaker movement at 30 htz stetsum gain up visonik down...did not know it was that hard of a concept.
and your last statement proved it. I dont like how you just seem to have every odd coax you can find in it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
oh I had lots of diff speakers in it, at one time, I had eclipse, kicker, zapco, alpine, and diamond. I just put stuff in anywhere if it fits. The poor woo has gone through many changes.
There are 6 redtop mounted in the wheel well and one under the hood.
Are those 34/78 Redtops? If so that a whopping total of 350AH battery bank with maybe 60amps coming from the alt? You could safely run about 3.5k for a little a while anyway. I hope stetsum denies your warranty when it blows. Is there at least a volt meter in the car? That's some lazy electrical for some decent equipment, takes power to make power chief.
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
talking about cheap but has a stetsom 7kd and 2 18's...
win
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Yep bought everything used, and traded some equipment.. have less than 2k into the entire setup..not counting the bats..but actually I started with 7 napa orbital O6s..all went bad and were replace free of charge with the red tops..so actually I did not pay anything for the redtops :)
  • Who's Online   1 Member, 0 Anonymous, 1123 Guests (See full list)
