00mgm Posted February 25, 2011 Report Posted February 25, 2011 Inspiring work man. I can see you do quality work. Keep it up!! 2000 Grand Marquis Digital Designs 9512 Rockford T2000bd1
pstone11 Posted March 10, 2011 Author Report Posted March 10, 2011 Boy, I have been really bad about updating this sucker, Been putting a bit of work in on it for the past couple weeks. I had to pull the doors off to make a couple adjustments and figured that it was time to get some speakers in there. I was debating on putting power windows in to free up some more real estate on the doors, but decided against it just for the fact that is something else that will break. Decided just keep the bottoms off the door panels and build up some new ones. Three 6.5's, one 5.25, and a nice tweeter in each door. Going to do some 4's in the pillars with maybe another tweeter too. First I laid out some fiberglass weave for the base of the mold, then three layers of 2 oz chop to get them solid. Here they are all laid up, one rough, one trimmed. I love these molds because they fit so perfect and tight into all the nooks and crannies of the door helps prevent rattles for sure. Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
pstone11 Posted March 10, 2011 Author Report Posted March 10, 2011 Trying how to fit the speakers in there and still clear the window crank. The big swoop above 2 of the 6.5 holes is for that clearance. The one below the 6.5 and 5.25 hole is just there to match. Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
uhoh_45 Posted March 10, 2011 Report Posted March 10, 2011 how many coats did you do? and you used fiberglass cloth right? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
pstone11 Posted March 10, 2011 Author Report Posted March 10, 2011 Making sure everything still fits, got them covered with some haynes tees, and that is when I decided to stop taking pictures I guess. As af today, I finished reinforcing the insides with chop and resin, they are ready for a little sanding and some vinyl. Next step is to get the pods wired and mounted up nice and secure, install some new parts on the doors, tint the windows, and put it all together. Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
pstone11 Posted March 10, 2011 Author Report Posted March 10, 2011 how many coats did you do? and you used fiberglass cloth right? For the molds I used weave cloth for the first layer to get a nice smooth air-free base. Then I did a layer of 2oz chop, let it dry. repeat 2 more times. Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
uhoh_45 Posted March 10, 2011 Report Posted March 10, 2011 ah thanks for the info the builds looking sexy as always keep up the good work R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
jay_dallas_bass Posted March 10, 2011 Report Posted March 10, 2011 DAMN!!!!!!!!! more pics?! My Build Log- The Celebrity
Kevin M Posted March 10, 2011 Report Posted March 10, 2011 Great build so far. I like the attention to detail. It's what makes a system shine. I would like to half your talent lol 2005 Ford Focus zx4 AMT's and Planars 18" Infinite baffle
finkster Posted March 10, 2011 Report Posted March 10, 2011 Nice work. Hopefully those tweeters make a debut in this truck DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
