Hey everyone got a question.
I have a 1996 gmc 1500 sierra
running 2 12in kicker l7 4 ohm
AQ2200D amp
3 Farad power cap
0 gauge wiring from battery to amp
all i have that i am using for battery power is the stock battery so my question is should i add another battery i have room under the hood to mount a battery on the driver side were a battery would be if it were a diesel truck.
If yes then any suggestion on what kind,size,power
thanks jake
Big Wheels Are Like G-Strings...Anyone can put them on but it don't mean they look good.....
yes. add the biggest battery you can fit into that space. maybe consider dropping the cap...
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
hows your voltage? you might not need to. if its pretty low, you could just get one big battery to replace your stock one.
MY TRUCK BUILD - 1976 F-100 Ranger. Fully built 482 big block, 4 DC lvl4 15's in a blowthrough, plenty of custom fabrication.
MY HATCH BUILD - 1993 Honda Civic DX Hatchback . Clean daily driver, dropped, subtle customization.
not sure on the exact number on voltage drop only meter i have is the one on the gauge cluster and it does not drop below 12 guess i should get and volt meter and something and get exact readings
well, my stock battery on my bmw was fine just added a walmart battery under the hood for starting. my voltage doesn't drop below 13.5 on an aq1200d. You should get a second battery but first find your exact voltage and then decide
I would change the stock battery first. Then if you still have voltage drop add the second battery. I would also lose the cap.
thanks, quick question though any reason to lose the cap? are they bad or something i am not much into car audio this is my first system. thanks
XS power D1400 in the stock location, and a voltage boost module for the stock alt. That would keep you in the 15 volt range, and would get you way more power from that amp.
^^^bad man right here. Best advice. Most people are gonna tell you to drop the cap, but can't tell you why. With the battery and voltage boost, it should be helpful. Your call.
2012 Honda Accord
Radio: Pioneer AVH-4200NEX
  • Who's Online   0 Members, 0 Anonymous, 2696 Guests (See full list)
