Skullz Posted October 28, 2010 Report Posted October 28, 2010 Open cell foam = bad things for a trunk seal. Closed cell foam is a much better option for stopping panels from rattles as it is a thicker and more dense material and less likely to hold water and breed bacteria and mold. If you want cheap deadening there is fatmat and edead to use, yes you can use peel and seal and it will work to an extent but it is made from rubberized asphalt which has polymers in but not a full butyl rubber compound type. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Ji553r Posted October 28, 2010 Report Posted October 28, 2010 i am going to try this stuff....most of my OEM rubber seal is gone so when my trunk rattles its very deep almost as deep as the bass because the metal is hitting metal so this will soften the hits and not sound so shitty outside but since it doesnt add weight and change resonance it is still vibrating just the hits arent being heard outside. i look at it the way people look at build logs...if the OP is happy, fantastic. i hope i am happy too about it I don't fuck around. I go from zero to I hope you die in less than 2 posts build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
Ji553r Posted October 29, 2010 Report Posted October 29, 2010 made a video about it come check it out http://www.stevemeadedesigns.com/board/topic/91705-weather-stripping/ I don't fuck around. I go from zero to I hope you die in less than 2 posts build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
BravadaBass Posted April 30, 2014 Report Posted April 30, 2014 Heres some fresh pics for Kranny http:/http://farm2.static.flickr.com/1055/5122147918_4ab244e657_b.jpg How would you do this for a blazer/bravada? Sub: 1 18" Obsidian Audio v1 Amp: Alpine MRP-M500 @ 2 ohms Wire: Belva BAK-02 HU: Pioneer deh-150mp Polk Audio 6.5's Polk Audio 4x6's 145.1db
Awhitewookie Posted April 30, 2014 Report Posted April 30, 2014 Bumped a dead one. Its pretty much common sense; you put it where your doors make contact with the body or get very close MY BUILD 1998 Ford Explorer 2dr sport 1/0 Big 3 1/0 everything Alpine cda-9884 Crescendo CZ components (2) Crescendo bc2000's (2) Jolt 150ah (2) Yellow top optimas (1) Juicebox black cherry addition (1) Mechman 270 avbm miss my bc5500 and (4) 15's You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
