So i picked one of these up to cut some holes but when i strap my router to it it covers 7 inch and below holes and i missing some thing here ?
2015 F-150 Platnuim
maybe your doin it wrong???? the 200 should cut up to 18 3/4 i believe........
maybe your confused between the difference of radius and diameter.....
Edited by Hugh G. Rection
Owner of BigAss Ports
The pin will still fit in the hole it just wont push all the way through. Make sure the writing side is down so you can see all of the measurements also.
its a pain to use you have to look from the top and add the pivot pin then find the hole where your cutting and cut steve has some videos where hes using it check it out on his youtube.
Edited by d-REW
tuTWENTY * Team MechMan * Team Shok * Team Sundown
i just got my router and my circle jig but i got no idea how to use it. i wanna make my circle rings for my 6.5" speakers and my 12" woofers and i really appreciate if some one can help me wit the sequence i need to follow i saw steve video but he only shows the sequence to do 8" can some one help me
thank you
Yeah When i first got this toll i installed it the wrong way , you want to make sure the letters are facing down.
If you want to make cuts that are small then the pin wont fit all the way trough but it will still work fine just
make sure the hole for the pin on the board is cut all the way through.
2015 F-150 Platnuim
  • 4 weeks later...
if you have a jasper and a plunge base router and are still having a hard time figuring out how to cut holes. i suggest you give up and not further pursuit this hobby or career.
the jasper makes life 100% simpler. its like using a multiplication table from elementary school. how hard was that?
NEUMAN
  • Who's Online   0 Members, 0 Anonymous, 4424 Guests (See full list)
