donpablo Posted November 4, 2010 Report Share Posted November 4, 2010 So i picked one of these up to cut some holes but when i strap my router to it it covers 7 inch and below holes and i missing some thing here ? 2015 F-150 Platnuim Link to comment Share on other sites More sharing options...
Hugh G. Rection Posted November 6, 2010 Report Share Posted November 6, 2010 (edited) maybe your doin it wrong???? the 200 should cut up to 18 3/4 i believe........ maybe your confused between the difference of radius and diameter..... Edited November 6, 2010 by Hugh G. Rection Owner of BigAss Ports Link to comment Share on other sites More sharing options...
CJ18 Posted November 6, 2010 Report Share Posted November 6, 2010 The pin will still fit in the hole it just wont push all the way through. Make sure the writing side is down so you can see all of the measurements also. Link to comment Share on other sites More sharing options...
01 S-10 Posted November 6, 2010 Report Share Posted November 6, 2010 Which router do you have? TDH FTW !!! Link to comment Share on other sites More sharing options...
TeejayBee Posted November 6, 2010 Report Share Posted November 6, 2010 Which router do you have? a jasper 200? Link to comment Share on other sites More sharing options...
Team-Atomic-Andrew Posted November 6, 2010 Report Share Posted November 6, 2010 (edited) a japer 200 is a jig not a router Edited November 6, 2010 by Team-Atomic-Andrew Link to comment Share on other sites More sharing options...
d-REW Posted November 6, 2010 Report Share Posted November 6, 2010 (edited) its a pain to use you have to look from the top and add the pivot pin then find the hole where your cutting and cut steve has some videos where hes using it check it out on his youtube. Edited November 6, 2010 by d-REW tuTWENTY * Team MechMan * Team Shok * Team Sundown Link to comment Share on other sites More sharing options...
pelon_1500 Posted November 17, 2010 Report Share Posted November 17, 2010 i just got my router and my circle jig but i got no idea how to use it. i wanna make my circle rings for my 6.5" speakers and my 12" woofers and i really appreciate if some one can help me wit the sequence i need to follow i saw steve video but he only shows the sequence to do 8" can some one help me thank you Link to comment Share on other sites More sharing options...
donpablo Posted November 17, 2010 Author Report Share Posted November 17, 2010 Yeah When i first got this toll i installed it the wrong way , you want to make sure the letters are facing down. If you want to make cuts that are small then the pin wont fit all the way trough but it will still work fine just make sure the hole for the pin on the board is cut all the way through. 2015 F-150 Platnuim Link to comment Share on other sites More sharing options...
neuspeedescort Posted December 12, 2010 Report Share Posted December 12, 2010 if you have a jasper and a plunge base router and are still having a hard time figuring out how to cut holes. i suggest you give up and not further pursuit this hobby or career. the jasper makes life 100% simpler. its like using a multiplication table from elementary school. how hard was that? NEUMAN Link to comment Share on other sites More sharing options...
