Mine just started doing the same thing...sometimes it works fine, sometimes it sounds really distorted and sometimes there no output at all, and other times there is no output. The whole time the power light stays on but when it sounds distorted the protection light blinks. i figured it was a ground or rca problem but i checked both with no luck. Was your protection light coming on while it was doing this too?
Yes, your's is acting the same way as mine. It cut off some time to time and also get distorted but the distortion goes away after a few seconds...
But i'm upgrading to the SAZ 1500 now. :drinks:
The Project!!
1954 Trunk Build
http://www.stevemeadedesigns.com/board/topic/102529-1954-chevy-belair-trunk-build/
The Daily!!
Head Unit: Alpine 9883
Subwoofer: 2 12's DC Level 4 XL
Amplifier: New DC 3.5 K
Rear Center Console: 1 8' DD 1508
Amplifier: Rockford fosgate 500
Mids and Tweets: Beyma tweets
e36 Trunk/Subwoofer Build
http://www.stevemeadedesigns.com/board/ind...showtopic=27903
  • 4 weeks later...
Christmas came early! I got my new toy today SAZ-1500d! Thanks Jacob!
The Project!!
1954 Trunk Build
The Daily!!
Quick question for you guys!
I hooked up my subs like this!
But the saz-1500d is a little different.
how would i hook it amp to the new amp...
just finish the blak and red line for me. thanks..
The Project!!
1954 Trunk Build
The Daily!!
very sexy, good thing you went with sundown. Jacob is the shit.
15" FI Q @ 1600 watts
box by DL Designz 2.8^3ft @ 32hz
saz-3000D @2 ohms
sax-100.2 @4 ohms
front stage - polk momo's
1/0 pos and neg runs to the back.
a crap ton of sound deading from secondskin.
143DB sealed on the windshield.
build log
thanks, so where do i connect the positive and negative wire too? i tried hooking it up on the left and right side of the speaker terminal and its not beating out hard... i know im not hooking it up right or something..... do i bridge it to 1ohm? how do u bridge it? ahhhh just draw the red and black line on the pix... my brain works better that way.... hahahah
The Project!!
1954 Trunk Build
The Daily!!
the 12volt.com has great wiring diagrams with pictures included..check there all u gotta do is select number subs and their impedance and bam..!!!! and the check with a ddm to make sure ur gettin the correct load
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
did you check all the wires to the subs before you disconnected them? that sounds like a loose wire.
yes, it's not the wire..
The Project!!
1954 Trunk Build
The Daily!!
my subs are wired up to drop to 1 ohm... i just need to know where the final negative and positive goes to on the amp terminal...
I already tried hooking it up to the left + - side of the amp and im only getting about a quarter power.. same goes on the right side of the - + right side of the amp terminal....
The Project!!
1954 Trunk Build
The Daily!!
  • Who's Online   1 Member, 0 Anonymous, 473 Guests (See full list)
