not eventually pretty much instantly.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
:facepalm: Not once have I seen anyone mention a resistor, if you're running a LED off 12v, you will definitely want a resistor otherwise it could eventually fry.
x2 resistors are a must... i got 2 wired up to the 12V line on my computer with a resistor but i cant remember how much, just do the formula for it which I cant remember either LOL long night... V=IR maybe... idk but Radioshack has both LEDs and resistors for real cheap...
and run the pos from the remote turn on wire? that way they dont stay on 24/7? but if you wanted it to flash with the beat : http://www.ledunderbody.com/led-interior-light-kits-underseat-underdash.aspx get a professional one so you dont have to worry unless your good at this (and judging by the fact your on here lol your not)
Edited by manofthehour
My stuff
'06 Scion xA:
-Alpine iDa-x100
-Alpine KTP-445 Power Pack
-Polk Audio db6501 (front components)
-Polk Audio db651 (back coaxials)
-2 RE Audio SEX12D4s
-Cadence F1200-1D
- Custom box tuned to 33Hz
- Kinetik HC1400
- 50 ft2 of Audio Technix sound deadner
- Big 3
My photography page
I know moetpoppin is pretty good with LEDs, he has a thread where he was messing with making sound activated LEDs. Here it is. You could try to PM him, I know he did it with transistors and whatnot, not too sure how though.
Need Test Tones/Sine Waves? Click Here!
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Pioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE Audio
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Hit me up on Facebook, if you want
what if there 12 volt LED strips?
and how would the leds break from the bass?
don't see them staying on or working too long from spl, and from the vibration of the box
R.I.P!
(Nov-29-2009)
92 explorer
current build
Yeah, true.
I don't think he knew they are semiconductors and have no filament.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
i'm also looking for some LED rope in purple for buddys box
R.I.P!
(Nov-29-2009)
92 explorer
current build
Dont quote me on this but i have seen it done and its on youtube. But i havent tried it yet. I have a module that controls my LED's and senses the bass its ok not too great but still cool. But i think you can hook up your 12 vold LED strip to your small channel amplifier if you have one. Positive to Positive and Negative to Negative on the channels so when the frequency hits the LED's will light up. Like i said i havent tried it yet but i seen it on a small amp i think 400 rms by 4 channels so mayble like 100 rms to each channel. Cant be to positive till i try but i havent had time to take my car apart yet
Vehicle: 2008 Mustang V6
Exterior: Blacked Out Taillights, Turn Signals, Side Markers-Black 18x8 Enkei ls5-6000k HID's
Interior: Blue LED Strips with Module for Music-Hardwired Beltronics RX65 with Blue LED and remote button
Sub: 2 10 inch custom subs
Amp: Hifonics BRz 2600
Wire: Knu 0 gauge
Headunit: Kenwood kiv-bt901
Damplifier: Fatmat Rattletrap
Electrical: Stock Alt/Stock Battery/Big 3
It doesn't matter which way you put the strip on, since the amp puts out AC anyway. Also, it most likely won't put out 12v. The LED strip will be a weird ohmage too, not a nice low number for your amp. So it could end up going poof when the bass hits.
What you want to do is make a nice circuit with PWM that varies the brightness depending on the signal level. Well, that's probably the best way to do it.
ohh like i said i wasnt very sure just seen it like that on the computer
Wire: Knu 0 gauge
this is way to confusing lol i think ill pass on it. i just wanted some light in my box :rofl:
  • Who's Online   1 Member, 0 Anonymous, 1545 Guests (See full list)
