remi_357 Posted November 18, 2010 Report Posted November 18, 2010 My current setup is 1 ap3k on 2 btl 15s. The 15s read 1.5 on every coil. It is wired at .75 ohm per channel.(running amp as 2 channel). I want to add a 2nd 3k into the mix. I can wire each amp mono at 3ohm. Or 1.5 to each coil. (2 channel setup). I don't want to wire .75 mono cause it says 2ohm min. Does anyone know what kind of wattage to expect from a 3ohm mono setup? Or am I wasting my money and not going to benifit from the 2nd amp?
dugee81 Posted November 18, 2010 Report Posted November 18, 2010 The ap is rated 3k @ 2 ohm, and 2k @ 4 ohm.. So maybe somewhere inbetween there? 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
slamin87 Posted November 18, 2010 Report Posted November 18, 2010 the most these amp give outis maybe 2900 at 2ohms so if its 3 ohms i would want to say like 2400 with good eltrical
loganberry Posted November 18, 2010 Report Posted November 18, 2010 Do a coil to each channel, 1 sub to each amp and with rise you will be fine My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
ALPINE408 Posted November 19, 2010 Report Posted November 19, 2010 Do a coil to each channel, 1 sub to each amp and with rise you will be fine That's a big NEGATIVE With a roll up burb yes you can do 1.5 ohms with rise but and this is a BIG BUT with music every time the sub stops moving between bass drops even for a second the amp will see 1.5 ohms and is below recommend usage. It might blow if you do this Have you ever had your woofers blown?
TeamHT Posted November 19, 2010 Report Posted November 19, 2010 Others have great luck running below 2 ohms. I didn't. Tell me...does this smell like chloroform to you?
BigPimpin91 Posted November 19, 2010 Report Posted November 19, 2010 That's a big NEGATIVE With a roll up burb yes you can do 1.5 ohms with rise but and this is a BIG BUT with music every time the sub stops moving between bass drops even for a second the amp will see 1.5 ohms and is below recommend usage. It might blow if you do this AP's are 2 channel amps. One coil per channel = a nominal load of 3ohms for the two internally strapped amps. It will be fine @ 1.5 per channel. Each channel is 1Ω stable. BigPimpin91's Banging Music
