Alternator Whine in speakers
So what do I need to check on the alts then? I got 4 of these puppies, so it is likely going to be a bitch to find.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
this is the point where I phone it in and get an rma. I dont do the alts bro.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Damn it, okay anyone else. I have a dmm and current clamp. I am thinking maybe unhook a few of them and see if the sound goes away?
Evo X build log
that would isolate it.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Just made some phone calls, sounds like it is in the amplifiers, the 3500's since when I disconnect the main RCA, I have the noise at an isolated rpm, if the noise was at the full rpm range then it would be an alt diode. It is only at 1500 rpm, which indicates a filtering issue in the amplifiers, since I swapped them slave/master and master/slave and sound still at same rpm, conclude it is a input filtering issue in both amps, with no signal connected there should be zero noise. So I need to get ahold of audio que and see what they want to do, freaking figures man, once I get my blown sub back, I have amp noise issues now, wtf???? LOL
Evo X build log
I got ahold of Audio Que they think it is a ground loop at the amps, since they are grounded at two different studs. So I moved them to the same stud. Whine is still there, I removed one of the rear batteries. Sound still there. Then I unhooked one alt at a time and sound still there, so I know the alts is not the problem. Anyone else got any other ideas to try?
Evo X build log
For sure its the amps? Try different amps? One amp?
That is my next thought is try one of the 3500s hooked up at a time and try them unstrapped both hooked, basically one amp running 2 of the 15's and see if it is still there, but I am 100% sure it is not being caused by the 4 channel amp and I am also 100% sure it isn't the RCA cables either, it has to either a ground issue or something in the one or both of the two 3500's.
Evo X build log
Fixed!!!!!
After a few days of testing and knowing I was losing connection power somewhere I decided to link all of the alts together with short pieces of 0 gauge and then connect that to the front battery. Fixed, all of the alt whine noise is completely gone. YES!!!!!
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 863 Guests (See full list)
