coil smell on cool woofer while playing (pic of amp setting)
So my L7s pretty well broken in now. Been playing it conservatively for a couple days. My gain is up about 1/3 of full rotation. Headunit sub level is 0. When I play some songs I get a little coil smell, so tonight as soon as I smelled it for a bit I pulled over and felt the sub and it wasn't even warm. I always thought the coil smell would only come from a pretty warm/hot sub. So I'm kinda puzzled if its really the coil or if I'm just smelling things. I'm more careful about my amp settings and such now since I burned up the 12" L7 I ran. But I don't have an o-scope so I just gotta kinda guess.
Edited by baaudio
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
Is that bass boost turned up? Sure looks like it.
ya i forgot about it. but yes it is. im gonna turn it all the way down and see what happens now.
Team NWSPL
baaudio Build Log
Anything past 3 dB of bass boost is risky business if you don't know how to set your stuff right. Bare minimum you should tune your amp with a dmm, if you don't have access to a scope. The cone/dustcap may not be warm, but the coil could have been jumping up to over 500 degrees, which will give you the coil smell. You are most likely clipping.
Need Test Tones/Sine Waves? Click Here!
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Pioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE Audio
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Hit me up on Facebook, if you want
Turn that bass boost off and reset the gain at least with a dmm if you don't have a scope. Also remember that your enclosure is huge so you shouldn't need as much power to get it loud. That box is the largest Kicker recommends so the sub wont have as much control as it would in a smaller box.
TDH FTW !!!
  • Who's Online   1 Member, 0 Anonymous, 1488 Guests (See full list)
