chrisiseffincool Posted November 28, 2010 Report Share Posted November 28, 2010 (edited) Okay, I've noticed it only does it really bad when my engine is cold and I'm pulling out of my neighborhood before school, but as I accelerated from 1st to 2nd gear in my 2002 VW GTI 1.8T, something happens. Basically the rpms get really high and it doesn't shift, and when it does shift the tires squeal and the car lurches forward. After it does this once the car drives pretty smooth again. It usually only happens when the cars been sitting in the garage overnight or when the engine's cold. Any suggestions? (p.s. the car is automatic.) (p.s. goodyear told me that the aftermarket exhaust has a few leaks in it, would that also result in a loss of power or anything noticeable?) Edited November 28, 2010 by chrisiseffincool Quote Current Setup: VW GTI 1.8T '02 1 15" Fi BTL Sundown SAZ-1500D Box-4.3 cubes Link to comment Share on other sites More sharing options...
SleeperSierra Posted November 29, 2010 Report Share Posted November 29, 2010 have you had the tranny serviced since you bought the car? Quote .ılı.——Volume——.ılı. ▄ █ ▄ █ ▄ ▄ █ ▄ █ ▄ █ Min- – – – – – – – -●Max Link to comment Share on other sites More sharing options...
Skullz Posted November 29, 2010 Report Share Posted November 29, 2010 (edited) My dodge neon does the same thing, best to let it warm up a tad before driving but if you can't wait then just when it's ready to shift just give it a few quick rev's to engage the gear instead of stomping on the throttle. Mine will happen between 2nd and 3rd gears so i have to get to around 50 mph before it will engage the gear so i just keep it in 2nd till 50 and then put it in drive and it will shift fine after that. considering what trans shops charge to rebuild them for me its just easier to let it go for now since i got this one from the JY after the diff pin slipped out trashing my other tranny with a broken transmission case. Edited November 29, 2010 by Skullz Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
EricM9104 Posted November 29, 2010 Report Share Posted November 29, 2010 When was the last time the transmission was serviced? Quote 2015 Honda Civic LX 4dr | 24k miles Stock H/U and mids/highs Power Acoustik GW3-12" D2 Sub HiFonics BXX1200.1D @ 1ohm Random 2.5^3' dual ported box NVX LOC Stinger wiring throughout 1977 Chevy SWB Cammed 350 Dual exhaust Cheap Wish stereo Link to comment Share on other sites More sharing options...
slow240sx Posted November 30, 2010 Report Share Posted November 30, 2010 Those transmissions r known to have some valve body problems that can cause a delayed and hard 1~2 shift. Prolly expensive to fix. Better just try to let it shift easy so it will last longer or get ready to spend a couple thousand when its time for a rebuild Quote 99 GMC Suburban 2 Death Penalty 21" 2 Crescendo BC2000 Boston GT-42 Amp 6 Selenium 6w4p 4 Crescendo tweets Hi output cs144 alt Audiocontrol Epic-160 Pioneer DVD head unit Link to comment Share on other sites More sharing options...
