you have 8 gauge power wire...
its like trying to suck a watermelon through a coffee stirring straw
Team_DC-Derrick's Youtube
Team DC Audio
Power and ground wire MUST be the same size....someone explain this in detail before, but I can't remember the exact reason. Has to do with the flow of electrons or some shit. Could be the problem...i would put something under the fuse..screw it to a piece of wood so it doesn't melt through the carpet and then ground out to your chassis and fire ball of doom.
hope that helps
pretty sure its 8ga ground and 4ga power, but either way thats pretty mediocre for that amp. Using smaller than recommended wire will cause it to heat up also..
Edited by Slawsen
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
yeah i know its pretty ghetto so do u think the power going through the 4 gauge and its trying to ground but there isnt a big enough ground to ground it maybe its kinda constricting it and compacting all the power to the fuse block or somthing idk
Currently in a build
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
Pioneer AVH-P2300 (next purchase)
High output alt 150 amps
hope that helps
ok yeah i think i might just upgrade to 0 gauge any ways \
and yeah i think im going to make an amp rack and put the fuse block on there
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
Using those fuse holders that you screw the wire down with are notorious on heating up and melting, use one that requires a lug on the wire before attaching to the fuse holder.
Here is one from darvex.
http://darvex.com/store/pc/viewPrd.asp?idproduct=353&idcategory=28
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
that audioque 2200 requires 1/0 power and ground
you need to run 1/0 for both
whats your electrical like?
my electrical is shit right now im considering switching it from .5 ohms to 2 ohms until i can get a new alt bat and 0 gauge
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
  • Who's Online   1 Member, 0 Anonymous, 1609 Guests (See full list)
