I'm planning on painting this bezel later and i want to shave the ash try. What is the best way to brace the open area? Should I use another piece of plastic to fill in the hole? Glue it or use a plastic welder? Or should I use fiberglass mat? I've done a little bit of fiberglass but not much. Thanks for the help!
Maybe put a panel under the opening and then glass and bondo it. That's what I would do
Ninja'd
Edited by YoungBuck
PM me for free Photoshop stuff
SAMSQUANCH!!!!
I'd glass it.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Cut a piece of abs plastic to fit then fill up the gaps with flex filler its made for that kinda stuff. Meade used it in his dash build for the hoe and chickens caddy cant remember the brand name maybe look in those build logs. Its good stuff i have used it as well
its from urethane supply
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Any more tips on if I can use wood or metal to fill in the hole?
I dont see why wood wouldn't work. just make sure to tear up that plastic nicely so you get good adhesion with glass. if you can, apply it from the backside so you dont have to smooth much of it out...but it sounds like you want to use the lip to place the piece into.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
  • Who's Online   0 Members, 0 Anonymous, 1012 Guests (See full list)
