trulywickedcustoms Posted January 17, 2011 Author Report Share Posted January 17, 2011 *2013 NEW BUILD* 12- 18" Crossfire XS v2's B pillar 4th order wall 4- Crossfire 8K mono blocks 40+ pro audio mids tweeters and horns 3- Singer alternator 400a external regulated alts tons of audiotechnix wire 24- XS Power D1400's -TEAM XS POWER- -TEAM CROSSFIRE- -TDH- Link to comment Share on other sites More sharing options...
mazdaspl Posted January 18, 2011 Report Share Posted January 18, 2011 Well after seeing all those boxes, we should start seeing the construction of a large enclosure soon.. Jay Link to comment Share on other sites More sharing options...
jeyrapboy Posted January 18, 2011 Report Share Posted January 18, 2011 cant wait to see the rest of this build!!! Link to comment Share on other sites More sharing options...
FieroGrande Posted January 18, 2011 Report Share Posted January 18, 2011 Dayumn I just had to change my draws, gOod work so far on running all the wires. Keep your hopes up and don't lose your motivation. Link to comment Share on other sites More sharing options...
trulywickedcustoms Posted January 18, 2011 Author Report Share Posted January 18, 2011 Got my DC stickers in for the caps an the 2 window stickers! The bolts for the subs should be in tomorrow as well as my 10,000k HIDs for my lows and fogs!!! Work tonight, staying up when I work off going to get 6 sheets of 3/4" birch some 2x6, resin, and other goodies for the start of the box build tomorrow afternoon!!! I'll post up pics as I go... Also doing the battery trays under the truck tomorrow before the box build starts! *2013 NEW BUILD* 12- 18" Crossfire XS v2's B pillar 4th order wall 4- Crossfire 8K mono blocks 40+ pro audio mids tweeters and horns 3- Singer alternator 400a external regulated alts tons of audiotechnix wire 24- XS Power D1400's -TEAM XS POWER- -TEAM CROSSFIRE- -TDH- Link to comment Share on other sites More sharing options...
dwright27 Posted January 19, 2011 Report Share Posted January 19, 2011 pick up some polyurethane as well and ALOT of sandpaper!! polyurethane the entire box and wet sand it smooth, then polish to help the airflow!!! 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer Link to comment Share on other sites More sharing options...
trulywickedcustoms Posted January 19, 2011 Author Report Share Posted January 19, 2011 Polyurethane??? Why not just resin the whole inside of the box then paint with a high gloss or clear coat finish?? And iv been doing alot of reading and iv read that 45s in the corners can sometimes hurt you... Any input on the 3 I have in my desgin? 1 under the port to help air flow to it, and 2 vertical ones in the back (the side closest to the back seat) Thanks guys *2013 NEW BUILD* 12- 18" Crossfire XS v2's B pillar 4th order wall 4- Crossfire 8K mono blocks 40+ pro audio mids tweeters and horns 3- Singer alternator 400a external regulated alts tons of audiotechnix wire 24- XS Power D1400's -TEAM XS POWER- -TEAM CROSSFIRE- -TDH- Link to comment Share on other sites More sharing options...
zayres29 Posted January 19, 2011 Report Share Posted January 19, 2011 finally some tits pictures Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged Link to comment Share on other sites More sharing options...
corona_jeff Posted January 19, 2011 Report Share Posted January 19, 2011 Polyurethane??? Why not just resin the whole inside of the box then paint with a high gloss or clear coat finish?? And iv been doing alot of reading and iv read that 45s in the corners can sometimes hurt you... Any input on the 3 I have in my desgin? 1 under the port to help air flow to it, and 2 vertical ones in the back (the side closest to the back seat) Thanks guys Unlike resin, polyurethane takes longer to dry so it smoothes itself out. When its dry is almost perfect. Once you get it finished all it takes is a quick wet sand with 1500 grit and then wax. Required alot less sanding. Link to comment Share on other sites More sharing options...
zayres29 Posted January 19, 2011 Report Share Posted January 19, 2011 Polyurethane??? Why not just resin the whole inside of the box then paint with a high gloss or clear coat finish?? And iv been doing alot of reading and iv read that 45s in the corners can sometimes hurt you... Any input on the 3 I have in my desgin? 1 under the port to help air flow to it, and 2 vertical ones in the back (the side closest to the back seat) Thanks guys Unlike resin, polyurethane takes longer to dry so it smoothes itself out. When its dry is almost perfect. Once you get it finished all it takes is a quick wet sand with 1500 grit and then wax. Required alot less sanding. this is nice to know i will be doing this inside my 4th order Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged Link to comment Share on other sites More sharing options...
