15" subwoofers that can do 2000-2500wrms daily
Emoxihax
The most important thing to keep the amp alive at low ohms is the person behind the knobs and the person that sets up the amp. ;)
I could wire a amp down to redicoulisly low ohm loads without blowing it up and i can blow up a amp at it's rated ohmage and blow it up ;)
(So n you're case it was probably the guy's fault that the amp failed.)
Cascade Omega, IA Death Penalty, SSA Xcon if your smart with the gain knob, RD Alpha Max, Cactus Sounds MK1, Crossfire XS, American Bass HD's, Atomic APX if you can find em.
Thats what I could think of off the top of my head
the atomic apx is rated at 1000rms the atomic apxx is the one that doesnt have an rms just a peak of 30,000 in a burp for the 15 sub the atomic ele is 2000 rms
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
But now you're quoting the exception, and not the rule.
Take for instance, you're very conservative with the gains at a lower than recommended ohm, you're adjusting the amp to output what the electrical will safely cover. Thus showing the electrical is still the most important factor when wiring down.
